Hello again, this is a continuation from about a week and a half ago as I was mowing hay with my sickle bar mower the tractor started to spit and sputter and eventually died not to be restarted. Initailly I checked the fuel and pulled the drain and the carb and it ran OK so I then started looking on the electrical end.
I bought a new batter yesterday and the tractor started, only running on about 2 cylinders though. I also have a new coil. I cleaned the points.
I am contemplating the next move. I am considering the following and would like some advice from the "pro"s" if possible!
I was thinking of replacing the points and condensor, I saw on this website you can buy a new ignition system that replaces them. has anyone tried that? Just curious if it was worth it.
Next I did find that the wire from the coil to the cap (the center wire) has one end that had a cracked housing. Like the metal had a crack where they had the center wire bent over against it for contact. I took the connector off and was looking at the center wire and I couldn"t even find one... Which I thought was odd although I assume they are quite a small wire. I am wondering if mine possibly burnt up or broke etc... Is this possible?
So I am going to buy a set of plug wires.
I also thought of pulling the carb off and soaking it for awhile.
what do you guys think? Am I making sense with trying to find this issue or no? Please point me in the correct direction if not.
Thanks! Mark
Thanks! Mark
