Super AV rear axle noise
ESVADuke
This past year I've been hearing a dull "thunk" at each rotation of the left rear wheel when cultivating.
Any ideas what this might be? missing tooth on a gear?
dangerous to keep running it this way?
any advice appreciated.
First check to be sure all wheel and rim bolts and nuts are tight. If
you have a wheel weight on that side check those bolts and nuts also.
Dave
You need to loosen up ALL bolts on the wheel add some oil to the threads and get them tight the wee if the noise is gone
because you have some that arent tight
My 300 was making a grinding and thumping at
semi regular intervals. I hit the Kashif
button thinking I had trouble in the axle
area. Turns out the the bolts holding the
wheel were loose. Unfortunately the threads
were d destroyed on several so I had to cut
them out and replace them. It was a pain
cutting them out but the problem was solved
for the cost of a few quality bolts and nuts.
Good luck. Paul
