Super C Carb
I have a Super C with 153 in it and I used a 140 manifold and carb and it runs like a dream! It will turn out around 40hp on a dyno with ease!
You can use the stock manifold but you will have to reroute the exhaust or make a new hole in you hood for the pipe.
Well if it will bolt to the manifold and the linkage will fit yes you could be you will most likely have problems with it running way to lean and it will lack the power it should have if it had the correct carb
