super c hubs
Check the axle diameter against an Oliver 66, Super66 or 660. They used 9 bolt hubs even on the cast wheels. 77's may also be the same.
The Oliver hubs are the same diameter but the keys are wider and since they are cast into the hub I have not figured out how to cut them down to fit into the axle slot. I have seen guys use 2010 JD hubs with keys altered to fit and I understand that MMZ or ZA hubs are the same diameter but not very strong. Migraine
I have a set of 9 hole hubs that were suppose to have come off of an Oliver.The S.C. has 2 1/4 axles and the hubs off of the Oliver were 2 1/4 also But they did not fit.There is about 1/32 difference in the fit.Still trying to figure out what to do to make them fit or trade for a set that will fit or go to plan "b" or "c".
