SUPER C LOADER CONTROL VALVE
Anonymous-0
I HAVE A SUPER C WITH A 2 POINT QUICK HITCH AND A LOADER BUCKET ON FRONT. IT HAS A HYDRAULIC LEVER TO CONTROL THE HITCH UP AND DOWN THE VALVE IS MOUNTED ON THE SIDE OF THE TRACTOR IT ALL LOOKS FACTORY. THE LOADER HYDRAULICS ARE CURRENTLY TAPPED INTO THE HOSES FOR THE QUICK HITCH WITH SHUT OFF VALVES TO SWITCH BETWEEN THE LOADER AND THE HITCH. MY QUESTION IS HOW DO I ADD A REMOTE VALVE TO CONTROL THE LOADER SO I DO NOT HAVE TO TURN VALVES ON AND OFF? THE LOADER IS POWER UP GRAVITY DOWN.
Trying to get a picture of that hyd system in my mind. Is there a steel hydraulic pressure line and a return line externally between the pump and the valve? I've tapped in on 3 different Deeres,a 60,730 and an MT. I just cut the small steel high pressure line,took a short piece out of it. Then I threaded both ends and put 1/2 inch black pipe couplers on each end. The pipe is too thin to hold up with just the threads holding them,so I brazed the ends on too. Then I just ran a hose from the 'pump' end,up through an open center valve,came out the 'output' side of the valve and back into the other end of pipe. Since the valve is open center,the oil flows freely through it like it wasn't there unless you're pulling the lever to raise the loader.
