Hello folks,
If you read my previous thread titled Super h starter issue here's an update and another problem. Long story short I was questioning the quality of my starter rebuild and was looking for advice about a replacement starter. The update is I decided to have my current starter tested at another shop and it tested fine. I inspected my wires and found a bad ground from the positive cable on the battery to the starter mount.
Now the problem. When the previous shop did the rebuild they replaced the improved style starter drive with the original style. Because I remember my dad having problems until he switched over to the improved style I bought an improved starter drive to install. Tonight I was installing it but I have an issue. The screw that goes into the detent on the shaft to secure the drive doesn't have enough clearance to unscrew far enough to allow the drive to slide onto the shaft. The top of the screw hits the shoulder on the drive. I'm lost and need help to figure this out. Can someone help me?
Thanks in advance.
Thanks in advance.
