Anonymous-0
There is no question about the necessity of using a supplied air or fresh air system when doing hazardous operations like sandblasting or painting with toxic materials. I know that I need to buy one but I would like to see if there is another way around this before doing so. What I would like to kick around is the alternatives of purchasing something like a hobbyair system and maybe save a few bucks.
Basically the hobbyair and others similar to it are nothing more than a high volume low pressure turbine probably no more than a two or three stage system where the output is somewhere around a few psi and maybe 5-8 cfm, I think. If so, has anyone ever tried to modify a low cost turbine air pump from let's say a H.F. HVLP paint system for this application? The only downside is that the air is quite warm out of one of these compressors.
Another option which would work quite well is using a old cpap machine which is used for folks who suffer from sleep apnea. This would work quite well if one could find a used one at a reasonable cost.
Other options are to use air from the main compressor but that requires a lot of filtering and I think that it maybe the least desired approach. I just don't like the idea of using air out of a tank where a bunch of nasty things may be lurking, but let's talk about that also.
Lastly, we have the option of using a vacuum cleaner blower. It too is a low pressure high volume system. Has anyone played with this approach?
While we are on the subject can we also discuss your experiences with face masks and hoods.
As you can see, I am a beginner and am trying to get some ideas and approaches to this very important subject.
