Army Guy
I am looking into doing some sweet corn this year to help with my addiction to the antique farm equipment. Can anyone point in a direction that I should head to be somewhat successful at my adventure. I will be using a JD 620 for all the field work and a JD 290 for the planting of the corn. I will be using a cultivator to keep the weeds down instead of spraying. Thanks
You might think about staggering your crop, in other words, planting several different batches a couple of weeks apart to stretch out your growing and selling season.
Are you going to sell at a market? Roadside stand? That's pretty big equipment for the typical market garden. You'll have to spray for silk worms.
You must be going to grow it commercially.
I used a 620 to do some row cropping. Had a 3ph cultivator. Cultivating with a hand clutch tractor was a little awkward, I usualley wound up stopping the tractor and then raising the cultivator. The tractor did not have power steering and I don't claim to be an expert.
The 620 will pull a 18 disk, 9 inch spacing, offset harrow, at least in my soil. The gas tank is over the exhaust manifold and after plowing for a while the gas would get hot enough to over flow out the gas cap which was a possible fire hazard. I tried insulation under the gas tank, it helped but did not end the problem.
I have planted Merit corn and like it.
I had to run an electric fence around the garden for deer and raccons. Top strand about waist high, two lower strands about 3 and 8 inches off the ground.
KEH
I made the mistake of planting an entire acre at once. It also all came ready at once. At first we were selling it, we finally gave it away to keep it from going to waste.
Plant it in about four or five sessions at least several days apart.
Sounds like you are not too much up on raising sweet corn. How big a plot total and how are you going to market. Now preparing soil you need plow disc harrow rotary hoe then your planter or do you plan on weed control by spraying also bugs how big a plot at a time which types of corn white yellow mised. How do you keep the different plantings seperated so the dont cross breed ect. Btter decide on what market so you know how large a plot to plant at one time go visit with someone who has doen it for a long time in your area so you get a better feel.
Don't be a bit concerned with having a bigger tractor.......always remember this, You can do small work with a Big tractor, but you can't do Big work with a Small tractor.
Your 620 and 290 will do fine....same as they did 50 years ago.
I reckon you found the right size plates for your planter....there's always a ton of them available on ebay.
Assuming a good growing season with regular rain and so forth, you should stagger your plantings by 10 days or so. My garden plot is 150 long.....so, I plant 4 rows at a time...which translates to a pass down and back and in ten days or so, I do it again. I'll generally have 16-20 rows by time I am done. Living in KY, I try to get the first seed in the ground by May 10. That translates into having made 3 plantings by the first of June. I'll plant a 90 day corn first.....I like Honey Select. If for some reason I get delayed, an excellent 60-70 day corn is Kandy King. I had a friend of mine plant this variety in July last year and he had a fine crop of sweet corn.
If your 290 has fertilize cans.....use 12-12-12, if not.....you can side dress it. At lay by...that last plowing before harvest.....I hit mine once again...this time with ammonium nitrate. Corn is a heavy feeder and that last shot of nitrogen will really shove it up. Some people think it a waste...but it makes a difference to me. Enjoy your corn patch and you might as well plant some green beans while you're at it.
I plant sweetcorn with a 2 row. One suggestion is to plant two different kinds of corn --- one kind in each box. Get corn with different maturity dates so once corn starts to get ready it is not all ready at the same time. I plant 4 different plantings about 10 to 15 days apart ---depends on weather, etc. Also, if you plant two varities they will pollinate at different times so more likely to miss bad storm, hot weather, etc with at least one of them.
Also, if planting two kinds make sure they are compatable as to pollination. For example, some of new supersweets should not be pollinated by older single cross corns.
Hope this Helps
John77046
I like to plant White sweet corn because it will stay longer in the field.
I plant 5 lbs of Silver King, 3 lbs of Seneca Snow Shoe, 2lbs of Indian corn and 1lb of pumpkins, all with a 2 row planter on a Cub. Sell everything at the house including the corn stalks.
If you plant more than 1 variety be sure to check the maturity times.
