Switchgrass and Ethanol production?
Finn Md
Anyone else see the NBC special that was talking about how switchgrass provides for more ethanol as compared to corn? We don't grow it around here in northern MD. It would be interesting if American farmers could make decent money also harvesting switchgrass for ethanol use. Any one out there knowledgable on this?
Be sure you get your terms right. Switchgrass makes more ethanol per acre and more ethanol on the net energy balance sheet.
The problem is that cellulosic ethanol production is in the very early research stages. Researchers are looking for the right process to make all of the efficiency theories reality. If it happens it will be a good thing. It is possible that in the future all of our organic garbage could be used to produce ethanol, now then, we would have found the mother load.
This whole deal is nothing new, it has just been brought to the front burner because of the fuel vs food debate.
Look at Brazil. They are self sufficient when it comes to Ethanol, which they call alcohol. They use mostly suger cane and have been doing so far longer than we have. For a country that is so supposedly "advanced" it amazes me at how far behind we are than some so called "lesser developed" countries.
Refuse disposal is another thing. The USA has only in the last 15 years started building "waste to energy" facilities that have been in Germany and other European countris since the late 50's!! What's even better is that these facilities provide their own power and sell off the excess to the local power companies. Tom
I haven't found switchgrass easy to grow. I used the county's special prairie grass drill but it still took a couple years to come up and the patch has much other grass, weed, and small tree material that doesn't mow so nicely.
The biggest problem I see with switchgrass over corn as grain is that I believe the volume of switchgrass will be signicantly greater per gallon of ethanol production and that storage space gets outrageous. Then the switchgrass has to baled and those bales tossed about, loaded, hauled, and unloaded, with far less ease than augering and dumping grain. Ethanol plants, even corn based, tend to not store more than about a 1 week supply of grain. So we farmers have to deliver weekly on their schedule from OUR storage. When switchgrass takes several times the storage volume, storing and hauling gets to a much greater task. Switchgrass grows only in summer (a warm season grass) and yields only one cutting and you have to careful to not cut too close to the ground or you kill it.
If my switchgrass patch wasn't usually too wet for a grain crop, I'd plant it in something else. Wet is supposed to be best for switchgrass.
Then there is the LITTLE problem that the enzymes needed to convert cellulose to sugar just barely work, without the effiency needed for production ethamol plants today. There are beliefs in the industry that adequately effective enzymes will be developed "real soon now". I don't have inside information.
Right now cellulosic ethanol is just beyond a "Pie in the Sky" dream. It may never work well, but if it works it may work equally well on corn stover, hay, switchgrass, wood scraps, kudzu, and scrap paper, if the inks don't kill the enzymes.
One plant has been announced in northern Iowa and in the last couple weeks on was announced to be built in Georgia to work with wood scraps.
Gerald J.
Here in Western, Pa. one of the local Universities is looking at switch grass. They have a lot of it planted and they are building a process plant as we speak. They seem to think that is a renewable, cost effective way to make ethanol.
Last night on History channel thay did a story on biofuels, and I believe the Ethanol per acre of switchgrass was 4 X that of corn.
Ditto to your message- especially that of the enzymes being developed. Current story is that good enzymes are about five years hence. But, that's the same story we heard 10 years ago. Current research also being done on cornstalks and corn cobs.
Finn: Switchgrass yes, but I'd forget the ethanol. Ethanol is being driven by the folks the make equipment to process the raw material into ethanol, plus the large grain companies who like it great when there is an over supply of grain.
Turn your switchgrass into pellets for direct burning in an industrial stationary burner or sell it to your nearby landfill. There is a landfill near me, they have piped it with Big O below the landfill soil seal. Plans are to vacume off the methane for burning. In fact they have already done a pilot project. One of the problems I see, modern day landfills don't have enough organic material. Municipalities are sorting out the compostables, leaving a high percentage of plastic going into landfills. Landfills are buying expensive fluf as a compaction material, to pack down all this plastic.
Basically as I see it, just maybe we can fertilize switchgrass with sewage, recycle the plastic and put all the compostables, switchgrass included back in the landfill, then we'll have a real power source. Doesn't take a whole bunch of sophisticated equipment either. Basically the one I saw running was a 150 hp natural gas engine off 500' of Big O, and not a very organic landfill either.
We don't have the proper climate to grow sugar cane to yield ethanol anywhere in the U.S. except for Hawaii. A few spots in Florida will support it's growth, but not good enough to yield a useful product. It takes a lot of land. In regard to Brazil, they've been trashing a lot of food-producing farms and woodlands to convert to sugar-cane for fuel. I suspect it won't work long-term and they will be in a worse mess later.
Either way, it certainly won't work in the U.S. We can't grow the sugar cane, and we also use a lot more fuel - for industry, and for jerking around - than Brazil does.
Yes, the U.S. certainly is behind in certain technologies - but many of them are bogus anyway.
Germany and the Netherlands have invested heavily into wind and solar-electric which DOES make sense, long-term. In regard to the often hyped-up "new" alternative fuels - I don't know of a single one that has been proven to provide a sustained yield over time. Many deplete soils, and use more petroleum to process and transport - than the petroleum fuel if it had been used directly.
Switch grass will grow on some pretty marginal soil. It is cussed hard to get a good stand but I pray for the day when american farmers can make a decent living and we can tell the sheiks to shove their filthy oil! Pellets seem to be a place to start. Imagine billions of acres of grass waving in the breeze. We need this.
Actually the switchgrass will make 7 times more ethanol than corn. If we keep messing with our food supply for fuel we will be paying for it with extremely higher food prices. Already Mexico is short of corn for the basic masa, corn sugar prices are skyrocketing as is cereal. cattle feed and at the present beef is very high. Corn is not the answer to our fuel supply. The only answer is hydrogen . It has no effect on the environment. Remember when food was short due to droughts or floods, other natural disasters. We need to find an easire way to sell and mannufacture Hydrogen.
University of Tennessee is doing a lot of work on it right now. Building a plant to do it. They say the only problem right now though,is that there is only enough seed to plant about 1000 acres. They're going to have to grow seed stock before they can supply ethanol plants on a large scale.
In response to Flashback, I don't understand how we can be short of cattle feed because we're using our corn for ethanol production. The by-product of ethanol production is the dry distillers grain that the feeders want. Its coming out our ears. Sooner or later the ethanol plants will have to give it away to get rid of it. Maybe we will need MORE beef to consume it all. Maybe the Mexicans need to start eating more beef instead of chimmenychangas. Maybe the people of this world can start paying the American farmer what he deserves for a bushel of corn just once in their lives. (And we haven't gotten there yet!) The cost of cereal is going up!! Boo hoo. What is there like 2 cents worth of corn in a box of cereal that costs $4.00? You should be whining to Kelloggs or General Mills. Yet I'll bet your the same guy that thinks nothing of spending a $1.50 on a 12oz. bottle of water. Hydrogen sounds like a good idea, but it will be decades or more in the making (if it can be done at all) on the scale needed to run this country and at what cost to redesign every aspect of our infrastructure to get it to every car in America?
By the way, how many of your neighbors own a hydrogen car at the moment. How do you replace every car, truck, tractor, lawn mower, atv, etc etc, millions of them in America alone? Because thats what you need to do to make an impact. Whats that going to cost the consumer?
Ethanol is here, its now, it works, its corn we would have raised anyway, its corn that would have gone to feed anyway and still does as DDG, it also took very little to adapt our industries and infrastructure to produce it, transport it or use it in every gas powered car/truck/tractor ever made and is available at every gas station in every state. All we have to do is ask for it at the pump. Run with it and trade in your corn flakes for some good ol corn fed bacon, sausage, steak and eggs.
Someday.
Today, it is an experiement, & does not produce more energy per gallon than you use to get there.
It has the _potential_ to produce more ethanol per acre than corn grain does, but that is only a theory today. It is not actual.
They need to come up with better enzymes to make it work more efficiently & more completely.
They feel 5-10 years it should be a _real_ thing with switch grass.
Note that corn stover (leaves, stalks, cobs) can also be used to produce ethanol, if we develop the right enzymes. Then we come back to a lot more ethanol per acre from corn, if we ferment both the grain & the stover.
Several farm magazines have had reports about the infant state of switch grass.
It appears it grows (well yields...) much better in southern USA, so little help to me here in MN.
It is very, very miserable to harvest - this has been a universal statement. No using the beat up old NH square baler to come up with the millions of tons of this stuff needed to fuel a plant. Seems a regular sized plant would need a semi load of switchgrass every 7 minutes 'round the clock. That is a _lot_ of volume....
It is like a summer grass - very hard to establish, miserable actually to get it to grow. Once established tho it is then very persistant.
I like all the media reports that talk about switch grass as if it were a real thing today. It's all theory today, but they hope to get there in a decade or so.
Likewise the sugar cane - Brazil has a lot of rainforest that doesn't treat regular crops very well - disease & fungus & such - but is _perfect_ for growing high-yield sugar cane, so naturally they are way ahead on that - it works there.
Corn is what works in the USA. In a few years, bio-mass from cornstalks, rice, wood waste, and switch grass might work even better.
--->Paul
I think that there is one very important thing that is being overlooked in the drive to produce ethanol from either grain , switchgrass or any other biomass source as an alternative and renewable fuel source to reduce/replace use of petroleum. It is soil fertility. It sounds good to be able to grow something, harvest it and turn it into fuel. But, the continued removal of a crop without addition of plant food in whatever form, be it commercial fertilizer, manure . sewage ,etc., will result in the soil losing fertility and producing lesser and lesser amounts. With fertilizer prices having increased as much as they have in the last year, and demand and prices increasing every year here and abroad, will it be economically feasible to grow switchgrass? Will producers of ethanol be willing to pay increasing prices that growers will have to have to fertilize the soil to continue growing the increasing amount of crop materials needed to produce increasing amounts of ethanol for increasing demand ? Increased cost of raw material will result in higher price for finished product. Will it still be economical? It becomes a vicious cycle.
Many people , I think are being misled, and are expecting to much about ethanol becoming their personal vehicle's "fuel of the future". How plentiful it will be. And cheap. After all, doesn't it just grow in the dirt ?
There is no such thing as a "free ride". It has been a "cheap ride" in this country for a long time. Those days are over and the "ride" is going to get more and more expensive. Everyone in this country needs to be more conservative of fuel, whatever the source. It should this country's number one priority.
I do not doubt that switchgrass can produce more fuel per acre, but how do get switchgrass to the processor? As for corn, we have hundred year old (with improvements) process in place.
Corn as well as celluose will no doubt, up gallons per acre in the future. I see corn as just a step in right direction until better alternatives are developed & are cost efficent
Apparently, the ethanol fuel hasn't progressed as well as planned. I live 6 miles from the largest ethanol plant in North America, which was, until last month, being built here in Indiana. The construction has come to a halt, supposedly caused by the high price of corn, and the faltering price of ethanol. According to the paper,this company has 7 plants under construction,at which, work has been suspended indefinitely at the present time.
I dont see why anybody would think corn has to stay at an artificially low price for any reason.I didnt see the show on NBC but I read something about switchgrass and from what I read they dont even have a plant to make alchohol from it yet.My impression is that its a bunch of hype to take focus off of ethanol production with corn,because what others said allready corn works in the United States.
Switchgrass might be allright if they can phase it in,in corn country,but they are still working on it,dont have enough of it,lots of problems to work out.Corns here and producing alcohol as we speak.Personally I would rather pay the American farmers than a bunch of foreigners that hate us.Keep up the cheap corn and American farmers will go broke.Im glad to see them get what is a better price but not fair price for their corn,it ought to be 6 dollars a bushel with the price of everything else what it is.
If corn was 6 dollars a bushel that would make that cereal really only worth about what 25 cents more than it was when corn was 2 dollars a bushel?How many farmers have gone broke and lost their farms for 2 dollar a bushel corn?More than half of them.
Lots of lies get told because big oil dont want you to burn anything but gasoline.We should be just like Brazil,and not buy any oil from the foreigners by now,and if it takes growing weeds to do it then we need to be planting them.Untill something better comes along,corn seems to be bothering big oil,and that should tell us to keep doing it.
