switching front ends, A
young gun
Currently have a roll o matic front end on my 52 A... Is there a front end to bolt on instead of the one I have that won't require me to swap out the whole pedestal piece on the front? Also, will it make the front end shorter or remain same height?
If you got a split pedestal you can put any front on single wheel non rollomatic square axle round axle 38inch axle etc........height should only vary with tire size ,,if you dont have a split pedestal not much you can change, maybe you want to find a split pedestal if you dont have one
Yes, you will need to install a "split pedestal" on your A if you desire to swap frontends in short order.
a none rollamatic frt will have lower ride
height. But I don't know if you could remove
the center shaft from a None rollamatic frt
& reinstall in a casting that was made for
a rollamatic.. ???
I pulled a non rollamatic shaft and hubs out of a mid 40s A and installed it in my 52A. I had to shorten the gear on the top that the worm gear on the stearing shaft turns, no problems.
