syringe test
Anonymous-0
take a old syringe from the barn remove the needle look at the port in the end where the needle fastens. Its a fairly small hole or port isnt it . Safe to say it doesnt flow verry much . The outside of the syringe is graduated into some type of volumetric usually ccs right. the black rubber tip on the plunger seals to the side of the syringes bore like a piston and rings do in a cylinder inside a engine right. Now then pull the plunger to the first graduated mark . then pull it to the next ever time you pull the piston / plunger further down the volume increases right just like adding stroke to a engine correct. Now then I would like for the peanut gallery to tell me how this volume increase from a fixed flow port would not increase the power out put every time you added more stroke. Thankyou for your time and head scratching. some teachers say that some only learn by skits so theres the skit.
Take that same syringe and use it allong with some plexy glass to check the volume of some M&W pistons so you don't have to cry to me for a week or two that it's "BS all the way", or that it's not possiable. When you figure it out, then take a caliper and measure from the top of the piston to the top of the wrist pin hole and add half the diameter of the wrist pin. Then you won't have to cry to us or lie to us either.
THen go back and read the "compression" thread. Go to a local grade school and have a 3rd grader read it and explain it to you
When you get that much done, you'll have done more constructive work and learned more than you have in the last 540 months, and you won't have to call anyone to find out. You won't bother them, you'll learn something for yourself and not look like an idiot in the process. It's a win win situation.
Just don't pull on the plunger verry fast, it's impossiable. Though if you drill the hole out in the end you can stroke it fast enough to wet the front of your pants. But if you drill the hole out, and shape the entrance and exit of the orfice correctly, it'll flow more air than if you just drill it out. A tough concept for some to understand.
I wonder what time break time is at the plant today. We'll see about the time this post gets quoted......
I can't expalin any more, not because I don't want to, but any more would be a waste of my time, some minds are not capeable of understanding. Those that are, will find the information on their own.
BS50 aint going to explain it cause he cant . Keep that koolaid cold salesman!! I just gave the shat that shows your ignorance.
pull the plunger as fast as you want the void wil fill . Why did your puller not get the famous quench that made so much power in dadas engine? just another hole in your story of lies.
Quit clogging the forum with your idiotic, childish and petty crap for lack of a better term in public. A horse's posterior and your post have a lot in common anymore.
(quoted from post at 16:50:43 06/15/11) pull the plunger as fast as you want the void wil fill . Why did your puller not get the famous quench that made so much power in dadas engine? just another hole in your story of lies.
If I'm so full of lies, then why do you pay such close attention to everything I do? Even though you mess most of it up, there's a few things you rember correctly. One day you say that I didn't have any quench in the one engine, but today I do.
By the way,
Congrats on those 2nd and 4th place finishes when pulling in the stock and 4 mph classes against other fella's pulling Allis tractors also.
Are you going to go pull anything this year? In your thread "some will be happy" you said you would go pull some. Are you going to lie to us? You also stated in that thread that your kids have no intrest in motor sports. Why do you fellas suppose that is?
See I didn't pick on anyone, I didn't make fun of anyones family or call anyone names. I just pointed out what has been shared in the past. I didn't waste any time trying to explain anything technical now did I. I just made conversation over information that has been posted here. None of it is fictional, it's all true. But it will make your head spin.
I do wish your family the best. I hope they turn out to be fine people.
Going back to work now. Rain day and I'm doing maintenance on equipment, takeing some family time. Helping a friend on his alcohol tractor and going to tinker on my own. At the end of the day, I'll have something done and something to show for it.
When did you become the syringe expert? You could even figure out the cc"s of an MW piston, called Wi50 a liar when he posted data, and then checked around only to find out he was right....
no matter what the head flows adding cubic inhes from stroke increases the horsepower . 427 bbc 425hp 454 450hp stroke stroke
Why don't you try what you are saying before you preach about it. It will suck the liquid up if you pull the plunger up slow but try to do it fast. It doesn't work very well.
that wouldnt have a thing to do with the material the needle pierces sealing around the needle and no vent would it.
