T-5 transmission
Anonymous-0
Can anyone tell me if and how to install a T-5
transmission from s-10 to 235 Chev.54 3600 pick-up?
Need alittle more speed and lessRPMS. Any help would
be appreciated. Larson
Hi Larson,
You may want to consider changing the ring and pinion in the rear end to a 3.55, I did with my '50 GMC, big help.
Dan 2N
T5 tranny would never hold up in a 3600 if you wanted to haul or pull anything more than a couple passengers. You need to look at a NV4500 5 speed from the early 90s. they were used in both chevy and dodges and the adapters to put them in about anything are available.
consider a browing aux transmission available in over str and under. find at old junk yards common on 1 ton and 2 ton
