ta 560 pulling
CAN YOU WELD THE TA SOLID OR BOLT THE FLYWHEEL SOLID TO CLUTCH SOME HOW OR WHAT KIND OF A JOB IS IT TO INSTALL A TA DELETE KIT HAVE THE TRACTOR SPLIT RIGHT NOW AND WAS NEEDING SOME HELP,THANKS GUYS HAVE A GOOD DAY HOPE YOU DONT HAVE TO USE A SNOW SHOVEL,
You may want to repair it. (I know that is not what you asked) they are fine parts of the tractor.
If pulling only in classes that do not allow TA use, the easiest method would be to put a new disk in the TA and not reconnect the external linkage.
If you are putting twice the power through the TA, a TA eliminator kit is best. If you weld the internal components you will have slag and beads of metal floating around in the trans, and no assurance that it will hold the power. It could be disassembled to get to the planetary gear set, and welded on the bench with professional level welding practices, cleaned and reassembled. Jim
Yeah, you can weld up the gears on the TA.
You can't buy a "TA delete kit" anymore. The tractor is 40 years old.
What is the purpose of bolting the clutch disk to the flywheel?
I think he means that he could bolt the TA clutch disk to the TA housing or (better) the TA pressure plate, then it would be locked up. I see no problem with that, it would take at least six 1/4X20 flat head grade 5 bolts around the perimeter.
With respect, Everything is for sale!! only the price is to be negotiated.
Jim
I'd keep the TA bc it sure is helpful in classes that allow it. Any fairgrounds/brush pull will let you use it. This will allow you to run a higher gear and still have the power in the end. You have to be pretty stout to tear it out. I don't pull a 560, but I do pull a SMTA.
Okay, 50. Maybe I'm in a state of denial.
40 years or 50, you still can't realistically expect to get a "kit" for anything on the tractor except maybe the carburetor. The fact that you can get as many individual parts as you can these days is a minor miracle in itself.
People are so spoiled these days by all the "kits" you can get... It all comes in a kit with step-by-step instructions on video easy-peasy, lemon-squeezy...
