I wasn't going to post this, as it'll be a while before I have the time to monkey with it, but since you guys are on this topic already: I have a B&S Elite Series 6200watt generator that is my back-up. I occasionally loan it out to friends when their power goes out. Well when it came back last time the guy told me it may not be right. Story goes: it quit running abruptly, he goes out to see what happened and notices the power has come back on in the neighborhood. All the circuit breakers are tripped. He resets them and unplugs the load (house) and it starts right up. I should mention he back feeds his house through the electric dryer 220V plug. He makes sure the disconnect switch is thrown so the mains won't come on while the generator is on line. Something must be off with his wiring? What happened? I suspect he may have his common/neutral and ground wires crossed on his adapter/back-feed wire. Even with the main disconnect disconnected isn't the ground still hooked up? Anybody have any theories where the current went? So I fired it up and hooked the air compressor up (220V load) and it appeared to work fine, but when the load was removed the governor almost shut the motor down very erratic RPMs. I tried the test again and this time it did shut down. Now all it does fires and runs for about 15-20 seconds and the gov goes all the way off, kind of slams to one position. I've eliminated the low oil shut down as a cause. It's more of a stall type shut down than an ignition kill. So what say ye all? Burned up coils in the head? Where or what should I look at before tearing into the generator head itself? Any suggestions....anyone?....Billy are you out there?
Busy day today (hot too!) I'll check back tomorrow. Thanks.
JD
JD
