TD6 international crawler
JDS1
I just recently purchased a TD6 crawler. Its a really nice looking crawler, but, needs some repairs. The fuel and vacuum lines where disconnected and I am looking for some kind of diagram to help me hook everything back up correctly. Can someone help with this minor issue?
First a year model would be helpful. Second try http://www.redpowermagazine.com/forums/index.php?showforum=9 these guys are the subject matter experts!
Rick
check with you Case IH dealer the engine is the same as a md so i think the line you are looking for might be to. try the on line parts catalog from a dealers site. won't have the td 6 because of ih selling off the crawlers but will have md might want to check and see if your local dealer might have kept the parts book also. good luck
Not any vacumn lines involved on a desiel (you said td 6) ih crawler that I know of. pretty streight foward from the tank to fuel pump ,to filters and to injector pump. You may be confusing the gas line that goes to the carb. is the only thing I think that could be confusing IF in fact you have a desiel td6.
A year sure would be a big help as there was more than one configuration over it's production life. Does it have the typical IH pump and dual filters?
If you can,t find us a serialnumber let,s try something simple does this tractor have sparkplugs AND an injector system? Or just streight desiel with no spark plugs
The serial # is TDBK22036TDI3B. I"ve tried to figure out the year but I've had no luck. I have figured out the fuel lines but there are two fittings that come out of the throttle/breather canister on the top. There is also a fitting on the fuel injector side on top of the head. There is also a fitting that comes out of the top of the fuel injector pump, between the fuel pump and the engine block. It has the standard IH injector pump with the two fuel canisters.
Well acording to the serial list on the left side of this page , it's a 49 . I don't have a listing for td13b at the end . T13b is code for front pto , light or starter ( delco-Remey heavy duty )Haven't figgured out how to post a picture on here , or I would of the fuel lines .
Just got an Idea , there's a video on youtube of a Td6 being rebuilt by Bored Iowa Boys . Should be able to see lines in video .
Coffee house, I appreciate the feed back. It does have the front PTO. I've checked out the video from Bored Iowa Boy on you tube couldn't see anything. I'm trying to crank on gas right now but I'm having no luck. I'm getting fuel and fire. Have any ideas?
There is a vent line that goes to the manifold, I can't remember where the other line goes at the moment. It is the pressure regulation vent back to the tank, but isn't used unless the pump is a B with the "IH" in big letters on the top cover. The vent generally goes into intake manifold with a little filter device. (B pumps just dump fuel overboard.) I need to dig through some photos.
Generally, not starting is either the ignition is 180 out, or the manifold butterflies are not snapping closed. They are critical to starting. A spring under the rear butterfly shaft cover pulls them closed, and if the shaft starts to bind or drag, the spring can't pull the lever over center. The mechanism does not force them closed. Lastly the ignition is interlocked with the manifold, although since you have fire...
These engines like very much to be choked, but will flood quickly. Rule of thumb is to count cylinders while cranking and on three push in on choke and then release starter. On a good engine, this happens at the same time. Even when warm, choke may be necessary for a piston or two. It is primarily a problem with the design of the gas part of the intake manifold.
Coffee Creek, Sorry about the coffee house thing, wasn't paying attention. Anyways my email address is [email protected]. You can email me the picture that you have. I've still not had any luck on cranking the old gal yet.
Call me anything but late for supper . You'll have your picture in the AM . Listen to M Diesel , the man knows what he's talking about . The linkage he's talking about will make a loud snap when changing over . No snap no start . take hood off , easier to see , linkage is behind manifold ( I think , now I'll have to look ) Where are you located . I'm in NW Pa , have the parts , service , and operators manuals . They come in handy .
M Diesel, I appreciate you getting back to me. Everything seems to be working OK, but, she still won"t crank. It hit a couple of times, but, that didn"t last long. Now all she does is turn over. Have anymore ideas? Coffee Creek, I live in Western NC. I"ll be looking for the photos when you get the chance to send them. I,ll have to invest in the parts, service, and operators manuals then. I appreciate you guys getting back to me on this. Maybe with a little luck well get her going.
Western NC? Ever heard of Rosman? It's a wide spot for sure.
Have you taken any pressure measurements? It requires an 18 mm plug adapter is all. When the cylinders go below about 60ish they won't kick.
We ain't kidding when we say that they flood easy. It will literally pool gas in the manifold by the time the engine hits the third rev, assuming the butterflys are closing. And if you don't hear them clank, don't bother hitting the starter. The choke doesn't have a spring loaded bypass flap. Some people crank on half choke, but none of mine really like to do that.
To help analyze the issue, I use brake cleaner as a starting agent. Spray it directly into the carb kinda like ether. It isn't nearly so volatile as ether and you can make it run on that alone with a little practice.
Are any plugs wet?
Never heard of Rosman. I'll check the pressure on the cylinders. It had a blown head gasket, the heads been reworked so I figured that the valves need to build up pressure. I'll give her a good looking over today.
M Diesel, I"ve checked out everything and all seems to be working fine. The butterfly valves in the manifold are opening and closing, I"ve got gas in the carb, and have fire on the plugs. The plugs aren"t wet so no gas to the cylinders. Have any other ideas?
At this point, ya gotta check compression pressures.
It doesn't need any run in time for valves to work. Something bad like the lack of fuel is either air sucking in through exhaust valves, butterfly not seated, decompression valves not actually opening.
Finally got her running. I checked the compression on the cylinders and had 60+ on each cylinder. It would turn over and try to fire up, but, just couldn"t quite do it. Got to messin around with the carb and noticed there was a plug near the overflow tube. I loosened the plug about three turns and she fired up. Once its running I can tighten the plug back up. I have to do this everytime to crank it. Is this normal?
I want to say no as I'm not sure about the plug and overflow tube. The carbs I have don't have an overflow, they flood into the manifold, where a small downward hole provides a drain. There is an adjustment screw on some of my TD9 carbs. Some of the bigger units had a mix adjustment on the carb for leveling off after starting, but have never seen one on a 6 engine. Not to say it didn't happen, or the carb has been changed out. (6 and 9 are same) Starting never involved leaving the seat, it was one of their advertising points for diesels. Any live adjustment had a control back to the dash. How is it doing on the diesel side?
Diesel side works fine. Has a little miss, but I'm hoping that might be air in the lines or a bad injector. I've bleed the injectors but that didn't seem to help.
I looked , mine has the plug by the vent tube . Looked it up in TC 23 E parts book . Looks like #5 primer connection plug . Looks like very early ones had a primer ? My best guess is you are venting the carb bowl ( some kind of air lock ). If it'll make you feel better I have to run the gas cap loose on mine to run on gas . Even after I switched caps with a running tractor 2x. Maybe blow out vent tube and passage is in order for both of us .
The primer stuff showed up in the early books, but seems to have gone away after a point. Not sure why. After getting the choke procedure worked out I haven't had any need for one either, so a lot of people must of thought the same. For whatever reason, I will say that my MD engine is often the hardest to start of all my gas starts. Sometimes it just doesn't catch on and take off as well as the bigger ones. It may have mag problems though.
Overall, I'm thinking that the engine isn't getting a rich enough mix. Possibly leakage around the butterflies. In the past I have found that I had to actually push them closed by working the fork with my fingers. They snapped, but did not completely close. Hoover the 18A had that problem for a while. While doing the head change last January everything got lubed from the inside and the problem went away.
PS: CC, watching the gas level drop in that little tank, it ain't no wonder the cap needs vented :shock:
That makes perfect sense. I'll check everything out and let you guys know what happens. I was wondering why it was using a lot of gas.
Keep us updated.
They consume gas like there is no tomorrow. That little carb does a really bad job of mixing stuff, but it gets the job done. Expect about 10 minutes of run time per tank. On the 18s the tank is bigger but I can see the level dropping as it runs. It makes you want to kick it over a quick as possible, but that is a bad idea. If it puffs for a while when switched, then it is missing and needs more time on gas. Usually another 10 or 15 seconds will do it.
FYI, the IH rule is to run no longer than 10 minutes on gas, and then it must be allowed to cool.
CC, You were right about the tube. The tube isn"t an overflow tube, but a vent tube. I took it off and sure enough it was stopped up. I cleaned it out and put it back on now all I have to do is choke it for a second and she fires right up. MD sure is right about it being a gas hog. No matter what I do it still drinks the gas.
