Got the TE20 from relative, it was running several years ago but he stored it for a long time and recently it would not start. When I got it home the wiring appeared to be in pretty bad shape so I rewired it using a diagram for the TO20 tractor. It has a Lucas generator and a D-R distributor and starter. Set the distributor to #1 cylinder TDC on compression stroke, new points, plugs, condensor, cap, rotor, set timing, new voltage regulator, ignition switch, two carburators, one Zenith, one Marvel, plugs produce good spark, blue/white spark will jump 3/8 of an inch from plug wire to ground but this tractor will not start. I have been working on this thing for 3 days now and cannot find the problem. I am probably too close to this and am failing to see something really obvious. Any and all suggestions to get this tractor started will be appreciated.
