Hi Guys,
Here is the response i received from Bareco reference upgrading my 80mm TEA motor(Thanks BOB for the link). Little hard to decipher what is meant in the second paragraph, but will endevour to get clarification on Monday. That being said it appears by the last part of the email that the 85mm kit fits straight in without any machining.
Obviously 87mm kits will not fit.
Hope this helps. Will place another post when i get para 2 better explained.
[email protected]]
Sent: Friday, 19 March 2010 3:18 PM
To: I-Cox, Warren L
Subject: Re: TEA 20 rebuild.
Der Warren.
Thank you for your email.
The only kit option for your 80mm bore TeA20 is the EK1 series of kits which upgrade your engine from 80mm bore to 85mm bore.
This upgrade kit liners are different in size where they fit into the block as the 80mm bore engine has a smaller OD where the liner fits into
the bottom of the block.
The 87mm kit will not fit your tractor due to liner sizes.
The EK1 series kit fit into block without any machine.
Kind regards,
Bareco
On 19/03/2010 09:05, I-Cox, Warren L wrote:
Hi,
I am currently looking for some technical advice on purchasing a complete rebuild kit for my 1948 TEA20 Ferguson tractor.
The current configuration is an 80mm piston and sleeved block with water pump mounted on the block not the head.
The engines electrical system has been converted to a 12 volt.
My question is:
Will an 85mm rebuild kit (pistons and sleeves) fit directly into my existing block without any modification, i.e. is the outer sleeve diameter and length dimensions for the 80mm and 85mm identical?
Likewise with the 87mm rebuild kit, will these fit my original block without any modification?
All assistance and help would be greatly appreciated.
