Good afternoon good folks
After my intro In This Thread, I promised feeddback as and when I got the opportunity to try your suggestions.
I checked the fuel valve on the tank and cleaned it out, ensured that there is a good flow of fuel through the in-line filter, and also opened the float-bowl drain to ensure that there is fuel right down to the carb (there is...). I also reset both adjuster screws to about 1 1/2 turns out.
I managed to locate the dowel hole in the flange, (it was plugged with old oil and muck and looked like part of the flange), and stuck a 6mm (1/4") bolt in there to locate the flywheel, with the rotor pointing to No. 1. I loosened the distributor and turned it until I had the points open, set the gap to .015", tightened the screws and then with the ignition switched on I turned the dizzie until there was a spark across the points. My understanding of the manual is that this is how it is done.
After tightening the dizzie, I replaced the cap and made sure that the firing order is correct 1-3-4-2.
Now this thing just refuses to start at all. I put a spare plug in one of the leads and held on to the business end while cranking the engine, and all I got was a mild jolt, with very little spark at all.
My knowledge of electrics is somewhat dangerous, but I did measure the voltage to the + side of the coil as 12.3v. At the - side (to the dizzie), I also get 12v with the ingition on. In other words, both poles on the low-voltage side are giving 12v simultaneously.
The tractor is running a 12v negative earth alternator
Is this correct, or do I have a bum coil? Maybe I should mention that while trying to start the tractor, the coil was rather warm, getting towards hot.
Thanks again for your input
All the best
Derek
All the best
Derek
