Frank Smith
I have studied all the numerous posts on rear axle oil leaks in Fergusons on this forum and must admit to being quite confused now. I am located in Brisbane Australia and have TEF20 Serial No 423672 with the Standard Diesel Engine. The tractor sat idle for some years, but I have it running well again apart from the brakes, which have had oil on them. The left brake has had oil on it for a long time, but when I moved the tractor after sitting idle, oil began weeping from the right brake drum assembly too so I suspect the oil seals had hardened and deteriorated whilst standing. I have new brake pads and gaskets to install but need advice on fixing the oil seal problem and that is where the confusion arises.
The serial number on this tractor indicates that it has the updated axle assembly with two oil seals on each half axle and the presence of a grease nipple on the hub bearing retainer tends to confirm that. When ordering the brake linings I also ordered two SURE oil seals, but after reading through this forum I do not know whether these can be used on this model or not. As I am keen to know exactly what to expect beforehand, what parts I need to replace, and to have the correct parts on hand, I have not yet removed the rear wheels and half axles.
So I would appreciate members advice firstly on whether my problems are likely to be the oil seals or simply deterioration of the gaskets either side of the brake backing plate. Secondly, is it likely that the outer grease seals (nearest the rear wheel) need to be replaced. As I understand it this would require removal of the retaining collar and bearing. Thirdly, can the SURE seals that I have be fitted to the half axles on this model tractor or do I need to use the original type of inner oil seal (the seal closer to the splined end of the half axle).
I look forward to your guidance before attempting the rebuild.
Frank
Frank
