Fuddy Duddy
Got my 2N going today with both a temperature gauge and a 160 thermostat. I drove it around around 45 minutes. Each time it would hit 160 degrees the gauge would drop down. After about 45 minutes it started staying closer to the 160 degrees. Temperature out side was 65. It was having a hard time staying at the 160 degree mark. This 2N does have a 6 blade fan. I was not pulling a load or bush hogging or any thing. Seems to be a fact that the best operating temperature is 180 degrees. So my conclusion is not to use the 160 degree thermostat. I was thinking that since I had a inline temperature gauge inline with the thermostat being farther away from the block a 160 might be better. But each time the gauge showed it reaching 160 it would then start to drop down. Take this information for what it's worth. A colder running engine is known to wear faster. No engines sold today have the 160 thermostat. O'course any thermostat is better than no thermostats. Most 'N's you find today have no thermostat at all. But my conclusion is when you do buy a thermostat for your 'N' get the 180 degree.
