Test Question
John B.
When I was in trade school over 30 years ago we had a question on a test and here it is.
If a 1 cylinder four cycle engine has to complete two revolutions of the crankshaft to complete it's 4 cycles then how many revolutions of the crankshaft in an 8 cylinder 4 cycle engine does it take to fire all the 8 cylinders.
Many in the class got this wrong! I was suprised!
Let me know your answers!!
In each revolution 4 cylinders fire and the other 4 are exhausting. Then on the next revolution the other 4 cylinders are firing and the other are exhausting.
But that's only if the engine is a gas or diesel
and if it turns clockwise or counter clockwise.
Gary
Think about how many times the crankshaft goes around to make the rotor button go all the way around once.
If 1 cylinder fires and completes the cycle in 2 revolutions, then the other 7 must fire before the 2nd firing sequense for #1 starts over. 2 revolutions. Chris
No question about it, it only takes two revolutions. I think what confuses people is that even though it's called a four stroke engine the combustion cycle is completed in just two completerevolutions of the crank. You've got to remember that fact each revolution of the crank causes two distinct "strokes", one stroke up and the other stroke down. So with a four stroke engine it goes as follows: Revolution one- down=intake stroke while up= compression stroke..... Revolution two- down=power stroke while up= exhaust stroke. So, two revolutions equals the four distince "strokes" of a four stroke engine. Wether an engine has 1,2,3,4,6, 8, 12, 16, 20, or however many cylinders all of them are attached to the same crank only at different degrees of rotation. All this means is that each will be on a different phase of one of the four distinctive "strokes" at any one time but all will still fall within the same rotational parameters as a single cylinder engine.
How many turns for a R4350 28 cylinder aircraft engine. It is also a 4 stroke. The answer is TWO. With more cylinders, there are more power strokes per revolution. Four cylinder, one power stroke for every 180 degrees of crankshaft rotation, 6 cyl. every 120 degrees, 8 cyl. every 90 degrees, 10 cyl. every 72 degrees, 28 cyl. every 25.71 degrees.
Kent
One cylinder fires on each complete revolution so to have all eight to fire it would take 8 revolutions. The only way it could be less would be to have more than one cylinder fire on a revolution.
It does not matter if only one fires at a time.
Each 4 stroke cycle takes 2 revolutions. If cycle 1 is intake, 4 of the cylinders start intake at some stage of the 1st revolution. Those 4 would have completed intake, compression, power and exhaust by the end of the 2nd revolution. For the other cylinders intake would take place during the 2nd revolution and be completed during the 3rd revolution.
If the "one at time" is staggered evenly the complete cycle would be completed on each cylinder in about 3 7/8 revolutions.
Wow ,lots of bad info.Guys are thinking that the power stroke must come first.The question is how many revs for a four cycle to complete four cycles.360 degrees of crank rotation x2 or 720 degrees.Intake ,compression,power and exhaust.Crank throw locations to each other dont matter.What if all crank throws where at the TDC at once and fire at the same time.While its true that the different cyls are at different timings to fire it still completes its four strokes for each cylinder[no matter how many cylinders in the motor] in 720 degrees or two revolutions.This aint rocket science.Power stroke 180 degrees crank rot;exhaust stroke another 180 up,intake 180 crank rotation then compression stroke 180 total 720 or two revolutions of crankshaft.Each piston has made four strokes up and down.
Yep know the question well because I got it wrong the first time so yep I know the correct answer and if you think about it, its easy it does not matter how many cylinders it has its always the same for all 4 stroke engines because all cylinder are working at the same time
Hobby farm
Example;cylinder one;intake,comp,power,exhaust cyl two;comp,power exhaust,intake cyl three;ex,int,comp,power. cyl four;power,exhaust,intake,compression. cylnder five and so on.all have fired in four strokes which takes two crank revolutions.
Joe MN is having some computer problems so he called me to post his answer. Here is Joe MN's answer.
"If you rearrange the letters in the word 'crankshaft' and leave off the c,r,k,h,and f you get, SATAN!!!!!!!. Obviously you didn't read the Bible or you woild know that Jesus was against all 4 stroke engines and in fact NEVER used one even once in his lifetime. He also didn't use diesels or those foreign junk tractors. I hope you are happy promoting Satan by asking these types of questions instead of sitting quietly in your room and reading the Bible. How else are you going to have the ammunition to look down on the rest of the world from your arrogant perch. Remember, stay at home, Read the Bible, and NEVER, EVER venture out into the world to offer a helping hand to anyone in need lest you be contaminated by their lack of faith and enlightment. Joe MN WWJD
Yep its like this. If one cylinder is doing something all of them are so if say #1 is sucking in fuel after 2 turns of the crank it will be right back at the same point it started with before the crank was turned those 2 turns and since they all are doing something at the same time all of them will be right back to the same point they where before you turned the crank so 2 turns of the crank will have all cylinder doing all they can do
4 stroke engine, as long as all pistons are connected to a common crankshaft it doesn't matter if its 1 cylinder or a V-16 it takes 2 complete revolutions for all cylinders to complete all strokes.
I believe it would be 1-3/4 turns to FIRE the cylinders, not necessarily complete the cycle in each cylinder. To get back to where you started in the first cylinder, it would of course be 2 full turns of the crankshaft.
Gary, you are right. I got thrown off because at first he states: "If a 1 cylinder four cycle engine has to complete two revolutions of the crankshaft to complete it's 4 cycles" so I figured it was how many revolutions to complete the 4 cycles for each cylinder.
John B.
In a 4cycle engine with a single cranckshaft it takes 720 cranckshaft degrees(2 revolutions)
To fire one and all the cylinders connected to IT. The camshaft rotates 360 degrees and determines the firing sequence.
Here is a question I had in one of my tests at school.
WHERE DOES ENGINE TIMING ORIGINATE?.
A...Camshaft.
B...Cranckshaft
C...Timing belt.
D...camshaft gear.
Lots of debates at times, only one answer.
Guido.
Soory Joe, only those looking for SATAN will find it. I'm sure that word is in many words if you rearrange the letters like you and your friend do.
Coloken.
Here is some higher knowledge for you
if its 4 cycle it still has to turn the crank 2 times to complete the cycles
