Test Question
John B.
I posted a comment this morning about how many revolutions of the crankshaft on an 8 cylinder 4 cycle engine does it take to fire all 8 cylinders.
The answer is two.
On a 4 cycle gas engine the distributor or magneto rotor turns one revolution to fire all the cylinders (no matter if it's a 1,2,4,6, or 8 cylinder engine). The distributor/rotor turns half engine speed. So to fire all cylinders it would take two revolutions of the crankshaft.
On a diesel engine with an injection pump the answer is the same.
A power stroke only happens ever other time the piston comes up.
I seen some interesting answers this evening after I got home.
Now that you have that figured out...
How do they use a mag that has two sparks per rev. to fire an engine with an odd number of cylinders. Like a 7 cyl, four stroke radial engine?
Yes. They do it.
I was wondering why the questions from a fellow from Iowa were disregarded. I was thinking along the line of a radial engine, that had an uneven number of cylinders. Maybe I'd better be quiet.
D.
I am not sure if this is the answer but they do run 2 mags, maybe mag 1 runs cyls 1-6 and mag 2 runs cyl 2-7. I know in my dads Cessna we test each mag in preflight check.
After reading your post this morning I heard some guys on the radio that are always calling people and asking really simple questions if you think about them.
Today's question was......
What is corn flakes made from.
They called 8 to 10 people and no one got it right.
(quoted from post at 19:59:34 12/29/08) I am not sure if this is the answer but they do run 2 mags, maybe mag 1 runs cyls 1-6 and mag 2 runs cyl 2-7. I know in my dads Cessna we test each mag in preflight check.
They run two mags and two sets of spark plugs for safety reason. (backup and better ignition)
No, the mags for odd number of cylinder engines are made so they can take care of it. Its done in the gearing from the armature to the distributor rotor.
I consider the original question 3rd grade to any mechanic, so I thought to throw out one a little higher in knowledge.
Coloken
In answer to How do they use a mag that has two sparks per rev. to fire an engine with an odd number of cylinders. Like a 7 cyl, four stroke radial engine?
Dual: Hall-Effect Electronic and Magneto
Coloken
I appoligize for the dual post
Any way the device used by rotec to supply ign to they"re radial engine
The all important ignition system utilises two auto type spark plugs per cylinder independently fired by both a single self-energized magneto and Hall-effect 12 volt electronic ignition system, virtually eliminating total ignition failure when used in tandem. Timing is fixed at 25 degrees BTDC of the CRANKSHAFT
Rotec R2800 Rotecradial engine
