Tractorcedric
- Location
- Garland. Utah
I am working on a Super C Farmall and had to replace the bad water pump. The water temp gauge was busted. I got a new gauge assembly and it did not read anything. The tractor was full of water and I worked it
hard on a burkley water pump for a couple hours. Still no reading, needle stayed at rest on peg. So I got another new gauge assembly and this time I just held the bulb end up next to the wood stove for a few
seconds and the needle moved. So I put it in and covered the radiator and let the tractor run for a while, even took it for a drive. Took the cap off and could see the water circulating and it was hot as well.
But the gauge was still not showing a reading. I have heard that some gauges on the market are for show only. If this is one of those, why did it read the heat from the wood stove? Bulb sensor goes into the
front of the head, right were the water returns to the top of the radiator. Thanks
