ou do remove the distributor from tractor to work on distributor don't you? For the highest percentage of people (those without the equipment, knowledge, skills to perform such cap tests) it is standard procedure to simply substitute another cap.(quoted from post at 19:03:31 11/30/22) It has been a long time since my electronics classes. Trying to get good spark on my 41 9-N, front mount. You know how hard it is to R&R the dist. I think the capacitor is the problem just want to rule it out. As always thank you for your help. joe
orry, my friend....that is not always true. The spark is much weaker w/o a condenser & sometimes they will not have a strong enough spark to run. I have verified , as you can see & hear.(quoted from post at 12:16:52 12/01/22) a capacitor/condensor is a little like a battery. will hold a charge for a short bit. When you put an ohm-meter on it, you will get a good needle deflection, then it will drift back to low. Then reverse the leads and touch again, once more it should deflect quick and way ovver, then slowly drift back towards zero. That would be a good capacitor. If it's open interanlly(defective) there will be no deflection. If the meter just shows a low and constant reading, its shorted.
If the capacitor is open, the engine will still work fine. The points will go back quickly!
ot much eqmt needed to determine cap value, shorted, open and exposure to 170 volts peak voltage. May not be perfect, but a pretty thorough test(quoted from post at 19:07:01 12/01/22) though a some what usable test, the voltage from a digital meter is not sufficient to do that (high impedance) the analog meter will do what you have indicated, but it will not provide the 200+ peak Voltage that can bridge a failed dielectric film. Jim
ery obviously, you know absolutely nothing about such ignition systems, so to prevent exposing your further ignorance, you need to remain silent.(quoted from post at 19:52:55 12/01/22) The voltage across any auto condenser never goes higher than 18V. Best not to apply 120VAC to it.
My experience with an ohm meter is that when the leads are first touched to the condenser, the inrush voltage used to measure the resistance(from the meter) excites the dielectric and shows a low resistance at first, and then the resistance slowly rises to > 20M ohms within about 15 seconds.
K, I was a little harsh last night, so I'll try this: Virtually all ignition coils of those days were 100 to 1 turns ratio, so when the points open and field collapses, the 20,000 volts of spark voltage 'transforms to the primary as 20,000/100 = 200 volts. Not just theory, but easily observable on an oscilloscope. Need more proof, hold your finger on the primary while engine running. Probably should skip the latter if you have a pacemaker.(quoted from post at 00:23:13 12/02/22)ery obviously, you know absolutely nothing about such ignition systems, so to prevent exposing your further ignorance, you need to remain silent.(quoted from post at 19:52:55 12/01/22) The voltage across any auto condenser never goes higher than 18V. Best not to apply 120VAC to it.
