Testing coils
grandpa Love
Can I tell if they are good with this tester? How? Thanks.
Check resistance across the primary terminals - should between about 2-1/2 and 5 ohms depending on the coil
Then check between the output terminal and the coil case - should be several thousand ohms.
But the above tests only coil continuity. As Hobo points out a coil can pass both tests and still be no good.
A low voltage low energy Ohm Meter test can show if a coil is definitely BAD like the LV Primary winding (maybe 1+ to 4 or so ohms) is OPEN orrrrrrrrrrrrrr the HV Secondary winding (several thousand ohms) is OPEN.
HOWEVER even if it passes those simple continuity checks, it can still be BAD due perhaps to HV breakdown once warmed up and HV is present.
It can show if its BAD but it cant tell if its necessarily GOOD
A cheaper Ohm Meter may not be all that accurate on low ohms readings
If I missed anything I hope the other fine gents can add to this
John T
Just put them back on the engine.Hold the plug wire. While someone turns the engine over. You will know for sure if it is any good.
