testing elec. wires
Anonymous-0
when my 49 ford n is running I can't check voltage my gauges go crazy when shut off but with key on there normal any Ideas thanks gene
(quoted from post at 09:56:30 08/28/10) when my 49 ford n is running I can't check voltage my gauges go crazy when shut off but with key on there normal any Ideas thanks gene
Need to use a analog meter instead of a digital meter
digital picks up on the field of the points and jumps around
Chris is correct. It takes a very good digital meter to work with old systems. As mentioned points in regulators, ignition, and RFI from spark plug wires all contribute to noise. In a digital meter the system samples instantaneous voltages over a continuous sampling rate (usually the same time it takes to settle down when hooked up to a battery when the vehicle is not running) this causes the meter to "see" voltages ranging from - peaks to positive peaks as its source. it then tries to display that as meaningful. High end Fluke (and other professional brands of meters) can filter, or compute out those spikes.
An analog meter with a needle display works wonders because it is continuous and the needle dampens the effects of random electrical noise. Jim
