testing generator
Anonymous-0
Is there a way to test the voltage output of a 6 volt generator on a 51 8N while it's still on the tractor ? I have a voltmeter.
Measure the voltage accross the battery terminals - withoutthe tractor running should be 6.3 volts or so - with tractor running should be 7.4 volts or so.
Loosen the belt and push the cutout contacts together with a wooden stick or your finger. The generator should spin like a motor. As the generator motor's, open and close the field regulator contacts. The rpms should slow some when the charging contacts close.
Sure, you can measure the output of a genny regardless where its at if its turning (more as RPM increases) and thats across it ARM terminal and its case/frame. However, the open unloaded output is not as informative of the voltage when coupled up to a load (battery) via a set of closed contacts in the cutout relay. A 6 volt battery just setting there tractor NOT running is around 6.3 volts but if coupled to a good working genny (cutout closed) it should raise to at least 6.5 and around 7 volts depending on RPM and state of battery. However the cutout dont close (to hook battery to genny) until the gennys voltage rises above 6.5 or so and if it never does its not gonna put out enought to raise the battery voltage as needed to charge it. I.E. if shes measuring only a tad over 6 on the ARM to case/frame shes likely NOT gonna close the relay let alone charge the battery.
John T
is the volt meter digital or analog
i have a digital volt meter and can not even get close to the tractor running the voltage jumps all over the place so i need to find a analog meter to check output while running
It is a sealed unit that you cannot open without completely running it, not like some of the Deeres were and newer ons for the Deere were sealed as well, to open them to see the points you would have to use a saw to open the cutout up.
Theres absolutely no need to open the cutout, simply use a jumper wire to short across it which has the same affect of applying hot ungrounded battery voltage to the gennys ARM post which should make it spin (if the armature and brushes and bushings are okay) with a loose removed belt.
John T
Buick, that's a "first" for you... giving advice some "hack" would try with the possible results of letting all the smoke out of the system!
If the cutout points are closed manually to "motor" the generator (if the battery is up to charge) they won't drop out on their own, and if they aren't manually popped back open things will soon get ugly!
Where Buick And deere said push the contacts together is what I was refering to as there is no way to see them let alone push them together without opening it.
Im with you, thats why I said just simply jump around the relay at its BAT and GEN/ARM terminals which accomplishes the same thing i.e. puts hot voltage to the gennys ARM post so it will spin like a motor if its good.
John T
