Anonymous-0
Hey folks,
My little tractor has been starting and running real well and just the other day started, ran around a while and baled some hay. Shut it off and it was a bear to get started again. finally took a shot of ether. Once started, it runs just fine. Was low on fuel so I topped it off. It's still hard starting and takes a shot of ether to start. Acts just like it did when the glow plugs weren't working a couple years ago.
I've got power to the plugs and when I connect a multimeter between ground and the end the wire connects, I have continuity. This means the plug is good right?
If my glowplugs are good, where else should I look? No water in oil or vice-versa, no bubbling in the radiator, just hard starting.
Tractor is a German made Farmall with a 3 cyl diesel motor (DD-111).
Thanks, Dave
Thanks, Dave
