Fighting suburbia in NC
Thanks to the board for the information provided when I inquired about the front-mount PTO stub shaft removal. Ended up being a LH thread type that backed out once I got 2 large pipe wrenches involved. The crank bolt is 15/16" and I used the bar between 2 pulley bolts method to hold the crank while I tightened the crank bolt. I will properly torque the crank bolt after I replace the front seal next time it gets back home to my shop.
I did find I have a bad sparkplug? now when I fired it up. Of course it is the #4 cylinder so I can't swap out a plug wire to determine if it is the wire or the plug. I did switch #4 and #3 plugs and it seemed to stay with #4 but the #4 wire ohmed out good. I will do a compression test next time I go up there and will take a set of NGK 3112s with me. Since it has been 7 or 8 years since I changed the wires I probably ought to take a set of them up there too. Seems like it is always something.
On a more positive note, even though the tractor is missing and Dad's S10 refuses to let me drop the distributor back in (oil pump drive is wobbling around) I did get to hang out and hunt with Dad. At 78 he still climbs trees in the dark and aggravates the crap out of me playing Devil's Advocate when I am trying to fix stuff that is refusing to cooperate. I lucked out and caught a large old 8-pt buck chasing a doe so now I will have a mount to match the 8-pt'er he has beside the rock fireplace. A little friendly competition for wall space and shared memories that offset all the aggravations.
