RED ALERT !! Ethanol
[ This is a do it at your own risk deal. Legal department deal you know.]
Last fall 2 of my McCulloch saws, a 940 two man and a I-62 5hp, were put to bed in perfect running order. Both of these saws had been run dry and both have the big old round Tillson carbs. This July I got several saws ready to take to the farm fair. These two saws would not run and I didn't have the time to tinker.
A few days later I pulled the carb out of the I-62 and took it apart. What a mess inside ! It looked as if a camel came along and took a dump in it!!! There was all kinds of black goo and little puddles of rusty water all over the screen. I also had to take the carb apart on my Gravely "L" Tractor. That carb had a big pile of black pepper in the bottom of the bowl. This was zink oxide from the pot metal! The black goo in the saw carbs was zink oxide, rusty water, ethanol and some other mistery crud. Another way this "zink rot" shows itself is a clear goo and little yellow grains that look like yellow sugar. Ethanol will pick up any water 'dry gas' and will go through your carb no problem. If this water rich gas mix sits it will rust the bottom plate of the carb and oxidize the metal in the carb. Different carbs have different mixes of metal in the "pot metal". Aluminum, Magnesium, Zink, Tin, Lead, Trace copper, Etc. In the old days it was pretty much what ever was around. Ethanol also attacks the rubber with swelling or shrinking or even it will shatter! Zama carbs that are used on late model McCullochs and lots of string trimmers etc. have very thin rubber and they shatter like pepper! When you rebuild the carb there is a little pile of black dust in the bottom.
All of this RANT covers ANY carb on other engines made of pot metal. Soooo.. here is where my test trial and error and a little research go.
The enemy is Ethanol in the gasoline and stabilizer does NOT help. As of today ethanol is mixed at 10%, this is soon going up to 15%!!! If you buy gas from a real sneaky dealer they add water to their tanks and the ethanol will pick it up. It will make them a little more money from the increased volume. Guess where that water goes?
This is where we need to start our journey. Find a good little independant dealer and see if he orders his own gas. He can get it without ethanol in it but it costs more. Price is maybe .50 more per gallon. This is BOAT fuel and does NOT have ethanol in it. I found one of these guys in Gap.PA. He said that people come to him BECAUSE he has ethanol free fuel! Never mind the extra cost. Boat fuel is for boats because Bay Cruisers and such have fiber glass hulls AND fuel tanks. The ethanol eats the fiberglass! This past spring a guy up in North Jersey bought about $100.oo worth of fuel when the price went down a little. About one and one half months later going down the Parkway he was pouring about $100.oo worth of gas on the road when the side of his boat finised dissolving! Find a local dealer with non ethanol gas or a boat dock with same.
Now another way around this is take a trip to you local camp store. Buy a metal gallon can of Coleman stove fuel at about $12.oo per gallon. This is what used to be called "white gas". I mix one of the little oil mix bottles with 3/4 gallon of Coleman to get a 32:1 mix that is better for my old saws and has a bit more stabilizer in the mix. Just beware that this gas is a bit higher in the octaine department! In normal 70-80 degree weather it is great. If you run your chain saw hard in 90+ degrees..and you don't let the saw cool down a little before you turn off the switch it will run on or pre- ignition. While it is running you can blip it a few times or just let it idle for 20 or 30 seconds. Then it should shut off.
Now with this Coleman mix you should run your saw, trimmer, small engine etc. and get it nice and warmed up. This will get the moisture out of the engine. Now let it cool off so it is safe to dump out any remaining gas. With all of the old gas out put maybe a 1/4 cup of Coleman mix in. Big tractors and such will need a little more. Start it back up and run it till the engine quits. Bingo... you can now put it away. I was able to "store" my two saws and Gravely for two months this summer and last week all of them started right up and ran perfecto. So try the Coleman mix or Boat dock mix. Sthil saws has sent their dealers a letter that says to use the middle octain gas and not the low stuff. CAUTION!!!!!!!!!!!!!!! NEVER NEVER EVER use airplane fuel. It is 100 octain and will fry your engine. It cannot be "cut".
Final part of story is down at the local large rental center store. They have a product in one quart cans that costs around $5.25 per. It is call "50 Fuel" This is a premix of gas and oil that is ready to use. The fire rescue, EMT units and any one like them are supposed to run dry any saw or chop saw or generator they use on a call. This stuff in the can or FRESH mix in a sealed saftey can is what they should use. The "50 Fuel" mix is good for two years in the UN opened can. There is no ethanol in the mix. It is a "TruSouth" product. www.50fuel.com. See if your local dealer will buy a diplay box of it for you and others.
This is as far as I have gone with my research and you must try it out for yourself. It is my 2 cents worth of data and that is that!! Hope it helped everyone out there and good luck.
Jeffcat
Jeffcat
