larry@stinescorner
the Ford did ok!That first stone is very heavy
Larry. That looks good.
42 years ago I was using a boom pole on an 8N years ago to put a huge carved stone up on the fireplace base I had built as I was building our house.
This was not the family 8N I have now.
I blew the gasket at the spot where the top cover goes on the tractor.
I wound up putting two heavy poles from the ground up to the base and sliding the stone up using chains and pulling with the tractor.
Had to raise it up about 4 feet.
Richard in NW SC
Good work. There is a certain satisfaction in doing the job yourself even if you do not have the fanciest equipment to do it.
