The Ideal utility tractor
Anonymous-0
I have three old tractors at present with all their deficiencies, and was wondering what an ideal utility tractor would consist of.
I would suggest:
Power Steering
Front End Loader
Four wheel drive
Horsepower ?
Transmission: shuttle shift?
Seat
etc
Please add your comments/opinions.
If I had a tractor with all and only those listed attributes, but NO live hydraulics, NO creeper low range and NO live-PTO . . . it would be pretty useless for much of what I do. No rear snowblower, no rear rototiller, and even brush-hogging would be at best - aggravating with a PTO that stopped everytime I touched the foot-clutch.
Power steering is nice to have, but it's only a convenience.
Front loader is great when you need it and often gets in the way otherwise.
I think "ideal" depends on the owner and what he/she wants the tractor for.
For me:
Power steering
Quick attach loader w/ skid steer style mounting plate
Four wheel drive
Ag tires
55 engine Hp
Power reverser
Telescoping draft links
Economy 540 PTO
Dual rear remotes
Cab with A/C
You guys just need to narrow down the model number of the new Kubota, JD or New Holland you want. Not many old tractors fit all those criteria.
Power steering
Live or independent PTO. Important for ease of use but more so for safety in using rotary mowers.
4 wd
Quick detach front end loader. Loaders are useful but not all the time.
Remote hydraulics, often necessary for FEL.
For current tractors, 45 to 55 hp. For an older tractor like the 135 MF, 38 hp is adequate. It's a question of weight and the torque the engine produces. Weight should be no less that the weight of a MF 135, sorry, I don't know what that is.
Concerning getting an older tractor with 4wd, be aware that the additional mechanical parts bring posibility of problems to look out for,
If you are talking about new tractors, they all will work. It's a question of comparing price and features and having a nearby dealer.
KEH
Ideals that don't exist on a utility tractor now?
-Hydrostatic on the low range/creeper cassette with foot control that goes up to maybe 5 mph.
-Shiftable economy/1000 pto. Its pretty rare on utility machines.
-Front three point and pto (ok so you can have it in europe)
-Front hi-vis hood option like Massey offers.
-Fender mount 3 pt hitch controls (Some have it now)
-Good high flow hydraulics on the loader. Once you've used a front mount post auger...
Ideal utility tractor is as follows:
Deere, Case IH or NH, Massey, Agco.
With 2.0 Liter engine, (basically about 45HP or more)
4 wheel drive
Hydrostatic drive, one pedal for fwd and one for reverse. The rocker pedal sucks.
3 range on the hydrostatic trans.
front and rear PTO
2 link spaced tire chains for winter.
R4 tires.
(heated cab for winter too)
Gun rack (for those pesky animules)
Power steering too.
And lets think of all the implements,
Rear grader blade,
front loader
rear grass cutter,
post hole digger,
tree chipper attachement too,
That should do it.
Yer supposed to buy it with "Stimulus" money. Just tell the gummint you got a "shovel ready" job for it and hire somebody to drive it for a week. Voila! Stimulus job created!
try to get a JD 4040s. look it up, by far the best tractor ever built. this isnt coz i've owned one or driven one on a regular basis but it has absolutely the best balance of power to wieght, might to agility. i feel it was a forerunner, unbeknown to JD, of high horsepower, low wieght and smll size which is much sought after now in modern tractors.
Count me in !!! Can we all pool together and apply ? external_link should have plenty of money for a combined project as big as we all can get.
And if you tip the tractor over you can use the new universal covers everything government healthcare. Actually it's gonna be rammed down your throat wedder you like it or not.
It would have everything that was listed, but most important, it would start when I needed it to.
Rick
My Mahindra 4110 fits most of the bill. But I added a sun screen since if I just look at a picture of the sun I burn.
All this new stuff is nice but i still say my ideal utility tractor is the one i already own. my ford 4000 and my 5000 both are circa 1965 one 50hp the other 65hp both are big enough for any utility job i bale hay with them ive run a 4 row planter my seed drill 3-14 plow 8ft wheel disc post hole diggers my 4000 now has a loader but its a recent addition i dont think its so much the tractor but your assortment of impements to use. and being from the 60s i can work on both and fix just about anything but the new stuff and all the computers and fancy electronics is out of my leage
