1969 John Deere 4520 with the correct 4520 engine (rear mount injection pump, JDB). I have owned this tractor for 3 years and have been slowly fixing it up. I have a starting issue and the compression is low. I have to use either, plug it in on a 65-degree day, or crank the snot out of it on a 90-degree day to get to start. Per the manual the compression should be between 385 – 410PSI @ 215 – 245RPM
I initially pulled all the injectors and tested compression and on average, each piston was about 300PSI. I did an in-frame overhaul and when I got the head off, the sleeves looked excellent, no wear marks or anything to my surprise. I pulled one sleeve just because. These were manufactured by Clevit and I did some research and was able to verify that they are correct for the application. While researching I located a set of NOS Cleveite piston kits a couple of hours from me, so I bought them for little to nothing and installed all of them for peace of mind. At the same time, I sent the head to my machinist, and he said it was cracked. It took some time, but I found a refurbished head and reassembled everything with a JD Head gasket. To my surprise I have the same issue, low compression (300PSI). I even put on my dyno, and it holds 125HP
I blamed the Clevite piston kits and sucked it up and bought the Reliance High Compression kits (I have had excellent success with these High Compression kits). I installed these and sent my refurbished head to my machinist and he said that the seats and valves were misaligned. He repaired this and I reassembled everything and still have low compression, 300PSI.
Currently I have the basic engine back together, but the coolant pump and hydraulic pump are not connected for testing. Oil in the pan and no water in the engine. Compression is still at 300PSI.
I have done the following:
Valves are set per the manual 0.018” intake and 0.020” exhaust. I have checked these several timed and even gapped these to 0.020” and 0.022” with no luck.
Before placing the head on I brought piston #1 to TDC using a dial indicator, this is within 0.001” of true TDC. The TDC mark on the fly wheel is about 3/16” off, but per my service bulletins it can be off as much as ¼’ with no effects.
I even timed everything based on TDC on the flywheel to the casted line in the inspection window with no change in performance.
Timing marks on cam gears are aligned along with TDC on the piston and flywheel.
Injection pump is timed.
Cranking RPM is averaging 225RPM (coolant & Hydraulic pump not hooked up) with photo tachometer
I have used 2 different compression testers, and both are within 5-10PSI
Suggestions?
