Again.
Alright everyone, hows it going? This afternoon I read through the comments on my last post about the trailer, and established that there really needs to be a gusset on the top side of the tongue, and I headed out for the garage.
I realized that welding on the back side of the tongue (facing the front of the bed) wasn't going to be easy. It could be done (and Ive done it twice now), but its hard to see what you're doing, and I wanted these welds to be perfect, so I had to come up with something else. After a little head-scratching and some quality time with the plasma cutter, I had a "T" shaped gusset made of 5/8" steel bar. I ground down the "plasma marks", welded it clamped up in the vise,
...and it fit right in where it belongs. I was happy about that, and I even used a straight-edge to cut it with
And then I set about welding it in place. I removed what paint I could with the grinder (not much), and then put in a first pass with 1/8" and/or 3/32" Hobart 6011, and then started covering it with 3/32" 7018. I dont know what amperage I was running at (you never do with the stickmate, just a "rough guess"), but Im happy with the way that it turned out.
So to recap, we started with an non-reinforced downhill (cold) mig weld. And now we have an open root 6011 weld covered with 7018, two fishplates, and a heavy-duty gusset. I dont think it'll break again. And I know that the plates arent perfactly straight, but my cuts are alot straighter than they looked in my last post, and unless you stick your head (or camera) right down there next to them, they look to be as straight as an arrow. That being said, I think next time Ill definatly set up the straightedge.
And for anyone whos curious, here are a couple of pictures of the trailer itself. Its about 15 years old, and the owner says it was the cheapest one that he could find then. He built it sides out of plywood he found in a dumpster, and uses it primarily for hauling garbage and the occasional load of scrap metal. Its actually not that bad of a trailer, Ive seen worse.
And so now he just has to pick it up. He was supposed to get it last weekend, but I cant reach him now and he has yet to show up. Oh well.
What do you guys think? I think I should have gussetted this the first time around, but thats a lesson learned, and now all I have to do is spend a little time on the post-weld cleanup and repaint it.
Side note, thanks for the advice you guys, you're the reason why I went back and re-enforced it. And to those of you who just want to slam my work, idk. Go find a hobby or something.
Have a nice night, everyone!!
