(quoted from post at 04:47:36 02/26/12) many older tractors do not have a water pump. they are called a burp system. water is moved by heat transfer. this is why the radiator gurgles after its shut off. an engine with a water pump flows water all the time, needing a bypass. the bypass allows the water pump to move water through the block and cylinder head until the thermostat starts to open. when the thrermostat opens the bypass flow is reduced and the cooling process is started-flows to the radiator and cooled water is drawn in on the suction side of the water pump from the lower side of the radiator. in my opinion with a wc if you want to get it up to temp put her to work. if it does not have a temp guege use a hand held temp gun. i love old allis chalmers tractors and i have my own, workin on one right now. don't be afraid to run it cold.
(quoted from post at 05:06:34 02/27/12) Early JD A,B.G,D Farmall 12, 20, 30 all ran without thermostats
and many are still running fine without them. Seems that engine
damage would have wiped most of them out by now. What I'm
saying is a trailer queen will likely not be hurt wheter or not it
has one. And honestly I've had more problems with a stuck
thermostat (open or closed) than i ever had with the old timers
with no thermostat/.
