Thinking about buying this trailer (picts)
Beatles65
This trailer is owned by a friend of mine that I work for. He said that he is looking to get about $500 for it. When he bought it the trailer was homemade. He put stronger axles on it and they have brakes that will need to be set up. It will need to be rewired and new lights. The trailer was originaly a car trailer and then he welded sides to it. I was thinking about buying it to haul tractors and other things to shows. I would have to cut the sides off though. It is 18 foot by about 80 inches. Tractors like John Deere A or one of my B's or the Farmall C. What do you think??? Thanks for your input from Nebraska, Andrew.
You do as you like but I think you would be better off to put in another $500.00 and buy a factory built trailer. You will spend more than another $500.00 fixing it up. DH
$500 doesn't sound too bad. Looks like 6000lb axles. Now you have to figure up what it'll cost to fix it up to you're standards.
I just bought an older 96"X18' shop built gooseneck.
Had to completely re-wire with two 2-1/2" sealed LED marker lights in each corner and two oval LED tails in back. Along with the grommets and pigtails for the lights the price tag for the lighting was $240 not including the wire, loom, and connectors, which I already had.
Another $200 went into new deck boards. I do tend to go a little overboard with my projects, but that's a good round figure to go by if you do want to freshen it up a bit. Jim
That looks like a nice trailer for hauling what is in it right now.
Sometimes homemade stuff can be a pain in the azz until you get everything right. The front hitch part looks lightweight to me. If you are just hauling those tractors maybe you could find a sturdier used 16' trailer that needs less work.
It doesn't cost much to fix the brakes or the lights. 500.00 is a cheap price and once you get the sides etc off it will look a lot better. Looks like tires are good but you will need fenders. Nobody mentioned what the floor is like.
If you can do the work your self it will be a decent buy.
We used to rebuild used trailers and there is websites that show you how to do everything you will need to do from getting the brakes to work to redoing the lights. Figure even if you spent another 500.00 you will still end up with a good unit at a fair price. I doubt that you will be able to buy a similar equipped trailer for 1000.00.
Andrew, IMO the ol trailer is well worth $500. But if you Do Decide to haul your tractor! Please, Please,,,,Lose that crappy, cheesy-a$$, bail style hitch and replace it with a good BullDog hitch!!!
It is ok for brush, Hay, and bulk stuff, I would not trust it with heavy concentrated wt like a tractor. Most especially when loading or unloading.
You will need drop post or trailer jacks to support the rear when in this process. Hope this helps.
Later,
John A.
80"is alittlenarrow for hauling tractors,unless they are set narrow.The trailer looks sound enough.$500 sounds like a fair price.Good luck Steve
The axles are worth $500 but for a trailer to pull a tractor, I'd look for a stronger better built one. You want to have at the very least a 2 5/16" ball with an A frame style coupler welded on. The middle support for the hitch looks like a poorly designed after thought to stop the hitch from bending up. The trailer in the picture doesn't appear to have any steel cross members between the the outside frame rails, which also don't look very beefy. They look like wood in the picture? If the cross members in the middle are steel going lengthwise or crosswise they should be turned with the longer side vertical to give the most strength. The trailer also needs fenders to be legal and possibly a break away switch for the brakes. The axles may also be a little too far forward. I don't think I'd trust that trailer to haul my show tractors. Heavier axles don't help if the rest of the trailer isn't as strong or roadworthy enough. That's my opinion as a welder. Dave
Don't know much about trailer construction, but the hitch isn't worth a plug nickel. Get a good bulldog style hitch.
While this trailer would probably do, I think you would be happier with a goose neck for pulling tractors.
originaly car trailer-- that means good for a 6000 pound load probably. Price is right for general utility purposes as is around neighborhood-- but as others noted if you"re going to be hauling tractors on highway you"ll have some work to do. Lot of car haulers are built lower to the ground for ease of loading, have -as this one- somewhat marginal frame rails. My "heavy" trailer is built on a old mobile home frame with heavier I beam frame, 2 5/16 hitch coupler- is plain flatbed over wheels so is fairly high off ground. Has a car on it now waiting for shop space but did haul some stumps to city recycling center -7800 pound load with minimal problems from bad loading job by tree cutter. Have about $400.00/$500.00 in it, frame with axles, wheels was $105.00 from salvage yard, another $100.00 for angle iron, another $100.00 for planking-tongue and groove salvaged oak barn floor. 19 foot bed with a 28 inch short beavertail. RN
I agree with the consensus below- worth the money for hauling brush, hay, etc- but if you have to modify it to haul tractors (max weight of tractor about 5,000# for that rig), you might as well get one already set up for it.
Get a 102" wide deckover gooseneck. 20'+5' dove tail with 3-5' spring loaded flip over ramps. I've had several other types and I really like the gooseneck.
