Lfdfireman
Had this discussion recently with a couple of ole tractor guys near me and I thought I would see what others say or do. Do you use thread tape (and if so what brand?) on things such as your sediment bowl, if
you were to replace it? Same question for the probe end that goes into the block for a temperature gauge. And for a gasket sealant, what do you folks use? For example, when rebuilding the carb and putting
it back on, do you use a gasket maker, a new gasket (and if you use a new gasket, do you put a gasket sealer on with it?). These ole guys had various opinions, some using thread tape and some say no way, some
use gasket maker while other say no way, use a new gasket and sealer. I know there isn't always a right or wrong answer, but it sure is fun hearing the stories!
