I am rehabbing a Ford 600.
I have done an extensive amount of work to it and I am in the final stages. I had removed the throttle hand control and now have reinstalled it, but it is not working properly. Since it has been a while I am not sure I reinstalled the parts correctly.
It goes through a bracket near the bottom of the rod and a bolt holds it in place by a groove or indention on the rod.
Below the bracket I have a spring and on the very bottom of it a cotter pin.
Can some provide a diagram or tell me if this sounds right?
I also put a new governor comp spring between bell crank and battery box.
The hand throttle has way too much free play and is not controlling the throttle as before.
Any and all replies appreciated.
