robbie wren
I have a 1951 8n that the hand throttle will not stay in place. When i open it up it will bounce back to about the midpoint or so. I use a flat tip to hold it open so i can mow. Any thoughts??
you can take the 2 bolts out & bend rod a little not to much then bolt back on.or put better coil spring in under rod.Chad HTH
(quoted from post at 11:28:50 09/02/11)
Check the balance spring at the bottom of rod going thru dash. Spring is probably broken or missing.
(quoted from post at 22:28:50 09/01/11)
o read the several post here & that ought to help you...........delete the * before hit ENTER.
http://www.nt*ractorcl*ub.com/forums/nboard/messages/174306.html
The small steel ball under the top throttle arm could be worn flat. I read of the peens being spread and a same size ball bearing installed. I just replaced the rod as mine had the ball worn and the arm broken and welded back on badly. replaced both lower springs as well.
