Tie Rod Ends
Todd Hertel
Looking for tie rods ends to fit a Co-op E4 SWF with part numbers TO-8870 and TO-8869. I can find parts for the AWF with TF-10800 and TF-1802 ends. Does anyone know if the tapered pin that fits into the steering arms the same?
Developing a power steering system that will require custom built tie rods but I need tie rod ends with tapers to fit the outer wheel steering spindle arms. No matter if R or L threads but would be ideal to find the correct taper with 3/4 x 16 threads or 7/8 x 14 threads. I plan on using tube inserts as found in the link below.
http://www.wfoconcepts.com/cr/Tube-Inserts/3207
T.W.
I might still have a table out of an old chassis parts books that had dimensions for tie rod ends. Do you have dimensions? Maybe we can cross them over?
The only critical dimension for me is the tapper. It appears to be 1:12 tapper. Top .720 bottom .645 and the length of tapper is .90. Their are 9/16" fine threads 5/8" long at the end of the tapper.
