Tig Conversion
Cman
Lanse, I want to ask you a couple of questions about the tig conversion from 225 AC to tig. I do have a 225 amp AC (only) Hobart welder. You really picked my interest with the conversion. I can't possibly think of any reason why I would need tig except my own gratification. I love to weld and this would be a new experience.
Question: Will this conversion work on AC (only). I looked on line and found a conversion kit, Weldcraft WP 17-25-R torch pkg. or WP17V25-2, torch pkg w/valve, but does not indicate AC.
I enjoy your posts and your enthusiam. I am retired and have run out of projects. I wish there was a site with various welding projects that a simple minded person as myself could build. Any suggestions, thanks again for your time................
Hey, no problem, thanks for the interest :)
Im no tig expert by any means, but I believe that it will only work on DC. AC tig uses high frequency to keep the arc going, and without that, I believe that your tungsten disintegrates. I think.
Honestly, If I were you, Id look for a DC stick welder. Just not a Lincoln tombstone with a DC side, because of the lack of infinite adjustment. Something like an old Dialarc or Idealarc would be nice, or a stickmate like mine, If you can find a nice one used.
Besides, if you got a used DC stick welder for tig, you would also have a DC stick welder!! Haha, once you try DC, theres no going back to AC. But back to the point...
Yes, you could run a tig setup off of your welder with a rectifier attachment. I looked on ebay, and there are thousands of rectifiers, but when you type in "welding rectifier", nothing comes up. You might have some luck finding one off of your local craigslist, and Ive seen more than a few home built ones. I dont think thats something that I'd wanna build, but people have done it before. Not to say that id want a homebuilt model, made by some clueless hack, but you might be able to find a nice brand name one. I actually just watched a video the other night on weldingtipsandtricks.com where the guy (Jody) was scratch start tigging off of a Lincoln tombstone with a rectifier. I dont think he could adjust it tho, it was more of a demonstration of how to use one. An adjustment of 15 amps like the notches on those welders provide is WAY too course for tig work. I learned that the other way, where as to get more heat when stick welding, I go by whole turns usually. With tig, its more like 1/4 turns, 1/2 at absolute most.
Well, good luck man, and have fun and be safe!!
BTW, I know that puddles has an everlast Power-Arc 200 inverter welder, which does DC and thus scratch start tig. They go new for $350, and its little brother (160) amp, goes for $300. He seems to like his, but ive never used one. If I were buying a new stick welder tho, thats one that i would really consider. Hopefully Puddles can chime in here, he knows way more about tig that I do!!
Again, thanks for following my adventures. I kinda like having my own little fanbase :)
Is that to say that my AC/DC Lincoln tombstone would not work at all or that it would not be desirable due to the lack of infinite adjustment?
You could possibly get an add on high frequency unit, but then you would be limited to aluminum only, and a very primitive setup at best for aluminum work!
It doesn't take much of a DC machine to do Tig work for steel and stainless steel. This is all I had for years! The slide amp adjustment was quite the challenge. :roll:
Later I bought this Miller, not a bad Tig machine, but an excellent 7018 machine.
You guys need to talk to the moderator and get your own forum. Yall are takinn over Tool Talk with the welding stuff. Get a "welding" forum.
I can run a rosebud, and start a fire with flint and steel, dropped some napalm for a big fire, so don't need the sticks and wire talk :)
Gordo
Thats not a bad idea Gordo, in fact, I just posted on the site comments forum about it. Lets cross our fingers, and hope for the best :)
Puddles must be hiding his Dynasty 300 inverter TIG machine. It changes everything you thought you knew about TIG welders. Still uses AC for aluminum but doesn'r need continuous high frequency(only needs HF for the start) and uses not only the same tungsten you use for steel but it's pointed the same. Conventional machines need continuous HF and the tungsten balls on the end.
I think the high frequency units Lincoln used to sell for the Idealarc 250, stated that the duty cycle was cut in half when using AC with HF. Lanse, the reason HF is needed on aluminum is because aluminum has an oxide on it that has a higher melting temperature that the aluminum itself. The HF basically burns the oxide off so you can get an arc on the aluminum. That's also why aluminum has to be really clean before welding. If you look at most aluminum welds, you'll see a kind of line on either side of the weld about 1/4" or so away on each side. That's the edge of the oxide. HF(start only) for steel is nice because it eliminates having to do scratch start to get the arc started.
