Tillage tractor recommendations
ed12345
Start up small farm down the street is starting up and in need of a general tillage tractor.
I'm thinking a IH 966 as the starting point for a 3 bottom plow, and 8 FT transport disc, and water wheel transplanter, 2 or 4 row corn planter, plastic layer. My first thought was a 686 but its a little fast for transplanting.
Medium-large frame 7,000 lbs+ and 65-110hp 966 is a little big but would work. Others would be a IH 686, Ford 7000, Oliver 1655, Oliver 1800, JD 4020. Looking for a 7,000+ frame and 65+ hp.
Looking for the least expensive tractor and repair cost with the best durability as these will all be higher hour tractors.
Let the color wars start --- Thanks
What kind of start up? Transplanter sounds like produce, corn planter can be field corn or sweet corn
966 is over kill for a 3 bottom plow and 8 ft wheel disc, I pull those with a much smaller 4000 Ford, just worked up 10 acres for hay pulling a 12 ft Oliver disc with my 6600 Ford
Tractor data shows 966 and 686 to have the same operating speeds
Why is the "start-up farm" not asking this question??
Yea I see they list them as the same speed but it’s wrong. Owned both and the 966 is definitely much slower at idle. 686 is too fast for transplanting cabbage
