Tire - Ballast filling
Anonymous-0
Well, a little elbow grease to get the tire off and rim repaired, saved a few bucks and learned a few things, so far so good.
When using the cheap ballast fill type adapter to fill a tire with ballast, you need to take out the valve core correct ? Tube has the ag air/liquid type valve, does that ag valve/core use the same tool to remove and replace or what am I missing, have to head over to Napa to get the valve fishing tool anyway. Thanks again !
yes you need to remove the valve core some tools remove just the small core and some remove the large quick fill core snd shell. most hold this piece in place so youcan screw it in when the liquid is replaced. we fill the tirre halv way to the stem and then bleed off extra pressure. then continue filling to top of rim. usually top off with 15 to 20 psi air.
