Tire Question
Woodwalker
I had a large cut in the side wall of one of the front tires on JD 5410. Installed a boot and it lasted for a month or so. I ordered and was sold a tire by a dealer as a direct replacement. Here’s the question, old tire was a Firestone 9.5L X 15, 6 ply, tubeless. New tire is a Firestone 9.5L X 15, 8 ply, tube type. Dealer swears the tube type will work tubeless with no problems. I’m not so sure. Firestone lists both tube and tubeless for this tire. Does anybody have any experience? I thought the beads and rims were different from one to the other?
99.9% of the time you will have no trouble at all,I don t think anybody has made a tube type rim in 50 years. If the tube type wont hold air then make the dealer put in a tube at no charge. Just as a side note,those huge Mickey Thompsons tires on the back of the hot rods at the car shows are tube type and are running tubeless.
The ag rim will have no "safety rings", the small raised rings at the bead area that make a car tire go POP POP when they are mounted. Without those rings it is real easy to roll a tubeless tire off the bead of an ag rim.
If your tire gets low WITHOUT a tube and you need to limp it to your shop for a shot of air, the odds of making that SMALL trip are not in your favor.
Have a tube installed. My 2 cents.
Those are just for show and not "for real". When we were racing stock cars, we always put tubes in Mickey Thompsons.
We've never run a farm tire without a tube, tubeless or not.
I'd stick a tube in it and go.
If you really want to go tubeless again, and you don't like the tire he got you, insist that he order you a tubeless type instead. I'd run the tube type with a tube in it and be done with it.
Donovan from Wisconsin
I have mounted a few tube type tires without tubes.
Had to use bead seal to stop bead leaks. Works good for a few years then the sidewall will get weather checked and start to leak. Tubeless tires have thicker and softer rubber on the inside to seal bead and to keep them from leaking after they get some age on them.
