Howdy, gang. Been lurking in this section of the board for a few weeks just reading, and I reckon it's finally time for me to ask a question. I have a '63 Ford 4000 that I pull with in the 4500# class...the tractor is a light-duty industrial (but NO ONE has said a word about it not being an ag tractor) and has 14.9 x 24 rear Goodyears, loaded, that are about 30% worn. Depending on the track conditions, I've pulled anywhere between 60' and 200'...which usually means I'm last or next to last in the class. I haven't noticed much difference in changing the tire pressure, although I've had it as low as 5 lbs with what seemed like a MINIMAL improvement. I think my problem is too much floatation in a light weight category...wide tires, not much weight.
So I have two options. Option #1 is taking the wheels and tires off my dad's 8N. They're 11.2 x 28, loaded, and probably don't have 100 hours on 'em. I'm kinda thinking that those tires might be TOO narrow.
But, as luck would have it, I also have access to a pair of 12.4 x 28s on a 9N we have (I'd just have to put the 9N rims on the 8N discs). These tires appear to be new, as you can still read the tire size on the cleats. I don't know if they're loaded or not, but there's 400 lbs of iron weights on each wheel, so I'm thinking that if the tires are empty, I could fill them with washer fluid (NOT a fan of CaCl!) and use the weights to get to 4500#.
My big question is: which option sounds better...11.2 or 12.4? Or would I be better off sticking with the 14.9 x 24s and coming in dead last at every pull?
Thanks for the help...
Pat
Pat
