tires for 620
NY 620
I know this has been talked about on here before, I am wondering how 12.4x38 will perform on my 620 while plowing and other farming task. I do have one set of weights on the back and looking to have the tires loaded if I do the 12.4x38 and looking at a set of front weights. My question is should I stay away from the 12.4x38 or should I look at a set of 13.6x38 or 15.5x38 which I currently have but need to be replaced. The rims I have also need some work due to them being loaded.
Soil Conditions are a concern; But typically a 12-38 with fluid in it should perform OK with a plow (depending on the plow also) except in sandy soils where bigger is definately better. Now for looks I have a "60" with 14.9-38's that are a favorite size for me. 15.5's dont look right on it; But a 620 might look better
Scotty
For a 620 I would use a minimum of a 13.6X38 tire. 14.9's or 15.5's would probably be the best choice. If you're replacing rims, get a pair of 14" rims, will work good on the 2 bigger size tires. Use a 12" rim for the 13.6's. Mike
13.6 38 and 15.5 38 have the same side wall height. The 14.9 38 is a taller tire. My 3020 manual shows a duel wheel option with 15.5 in the inside and 13.6 on the outside.
If you want a larger tire consider the 15.5. The gear speeds will match the manual, the draw bar height will be stock, the ride height will be stock, the ride level will be stock compared the proper sized front tires.
Tires with lug angle close to 45deg look less wide than the 23deg tires while still getting the rubber to the ground, in my opinion. After much consideration, I selected 15.5 BFGs for my A shown plowing my steep sandy slopes.
Mark
I have 13.6x38's on my 60. It came with 13-38's (14.9's) I would go with the 15.5's. Same height as the 13.6's, but better traction. I would aslo go with the wider rims.
Tom, I respectfully disagree that a larger tire looks bad on that size tractor. I think the small tires look too small on that size of tractor. A 13X38 (14.9X39) should have been an option on a 620 (it was on a 60) and 15.5X38's were optional on a 630. I had 14.9's on my 60 until I got a smokin deal on a nice pair of 16.9X38's which are on there now. The tractor now sits level. As far as the tire having too large of a "footprint" a 620 was only 2 hp (PTO) less than an "R" which had 16.9X34's standard with 18.4X34's and 23.1X26's as options. I do acknowledge that an R did weigh more, but put some ballast on the 620 and let er rip. Here's a pic of my 60, like it or not. Mike
12.4 look good on my 50 and they would be ok on a 60. 60, 620 orginally came with 12.4s problem with 14.9x 38s is price they are very exspensive...and i know this because we priced tires all day today. 14.9 firestone field and roads are between $600 to $700 each. ive been looking for a used set but they are hard to find. it all depends on how much you want to spend
The 16.9's are on 16" rims. I have pulled it on occasion in the past but not for the last couple of years. The trailer is always full with our 2 A's. Mike
I agree Mike. Just about everything I have ever owned I have put larger tires on, they just look better and in my opinion perform better.
Mike
