Tires, tubes or no tubes.
I'm new to tractors bigger than a JD 318, just bought a 1949 JD MT and I need to replace one of the front rims and tire (rim is rotted away around the valve stem). The existing rim has a tire with inner tube, the question I have is are inner tubes still a necessity for tractor tires or can I go tubeless. The closest thing I owned to a true "tractor" before this month are 2 JD 318 garden tractors an of course they run tubeless tires.
Any help would be appreciated.
i run tubes, works better for me. if the old rim is just rusted around the valve stem hole, maybe you can weld the hole shut and re-drill the valve hole around the rim where there is better metal.
(quoted from post at 14:08:21 03/15/10) i run tubes, works better for me. if the old rim is just rusted around the valve stem hole, maybe you can weld the hole shut and re-drill the valve hole around the rim where there is better metal.
There's not a whole lot of metal around the valve stem, you can see the tube inside and the hole is about 1/2 by 1 1/2 inches big.
I'd grind back the hole to good metal (1"x2" sounds like it might work) Then I'd do as Glennster suggests as long as you're doiing the patchwork. If you can find a deal on a good used rim and you'd have to pay someone to weld the patch, then replacement may be the way to go. I'd stick a tube in it in any case.
I'm gonna go with everyone else... Tube it, in the end it'll work out better.
All of my stuff is tubed, except for my plow.. Still don't know why it ended up without tubes, but for the little use it sees, it's been fine.. But growing up on the farm I remember Grandpa and my uncle having a Krause field cultivator, seemed like it was always getting dirt into the bead and before you knew it, the tire was flat and off the bead. They had a similar problem with their no till grain drill too.. Tubed it up, and never bothered after.
Brad
This has worked well for me. Get a small fiberglass boat repair kit, sandblast the area around the stem hole for several inches inside and out and apply a couple layers of the fiberglass cloth to the inside and a layer to the outside. When the resin sets(give it a day or two), smooth it up with sandpaper and redrill the stem hole. Fiberglass is stronger than steel and if you do the job right, will last forever.
Although you may have a tubeless tire, you may not have a tubeless type rims. And if so you will be fighting slow leakers till you put tubes back in them.
NO rim made before the mid 60 was made for tubeless tires at least on tractors. If you try to run a tubeless tire on a tube type rim #1 it can be unsafe and #2 will not be likely to hold air long if at all. Run the tubes in them and be happy your have tubes. Tractor tires get twisted and torqued a lot and because of that the tubes help a lot and in the case of the older rims are in fact needed
If you had tubeless type wheels that are fully welded and in good condition I would suggest, absolutely that you go tubeless.
However, you probably don't... so you'll need tubes.
Most people that squalk about using tubes never ran enough radials to have constant tube problems that recur while using tubes in low inflation tires. Simply put, tubes are not always the answer.
Rod
For what it is worth,I'am running over 200 tires on the farm and all but maybe 15-20 are tubeless plus I'am running tube type tires tubeless on a pulling tractor and they hold air fine.A lot of tire dealers mount all their front tires without tubes unless the farmer demands tubes.It is your call and only you have tobe happy.
