robertw
Is goodyear duratorque 15.5-38 tires a good choice for a farmall m pulling in antique stock 6500 pound class or is there another brand that might work better i plan on getting new ones as mind are worn down and don't hook up on loose tracks vary good on hard tracks they do good by the way the ones i have on now are 13.6-38 firestone field road 50% tread the bars are rounded some it had a 3 point hitch when i got it i think it had a lot of back and forth action spinning on the tires
Thanks Robertw
there aint a tire made that will hook up on a loose track.loose tracks require a lot of weight management and air pressure settings to get a good pull on
As mentioned weight management. You may want to try deflating the tires down to 10-15 psi. Also, that M should pull better in 8000lbs class on a loose track.
