Fixer
I recently finishes renovation on an M Farmall. Didn't want to go imp0rt so bought Goodyear tires for the rear. One tire seems to have a hump in it. Tractor bounces up and down going down the road in high gear. So far have centered the rims on the wheel centers. Removed the offending tire. Checked the tube for balling up. Changed the bad tire to the other side. Problem follows the tire. Question is. Can a tire be made out of round? Anybody else ever had this problem? Thanks Bernie Steffen
Do you see any bulges or broken belts?
I've had that happen, granted not on a new tire and not on a GoodYear... but it's happened.
I'd be taking it back.
Now is when you hope you had the tire shop mount those tires... or I'd expect a fight from them on just about any method of squirming out of paying.
Rod
Yes, you can get a tire out of round. Brother inlaw had new tires put on 1486, it bounced and jumped, road rough as heck. He talked to tire shop and they put a new on and it was fine
TAKKKKKKEEEEEE IT BAAAACCKKK.... NOW! Before they decide to say, hey, that was a good tire.
Get it back! We bought some Titans from Jr. Tucker tires mail order once...one had the same problem, eventually the belt completely broke and it ripped along the bead, tube began to pop out. They also started weather checking real early. Have never bought anything but Goodyears from a local dealer since, including the replacements for the Titans!
Yes, GoodYear Ag is now owned by Titan... but as far as I know the old GoodYear tires are still GoodYear's. It's the ownership that's changed, not the tires.
With that said, I'll not ever buy a Titan branded tire so long as I can get anything else...
Rod
Anything manufactured can be done wrong and new tires can be out of round. I take it that you bought these tires and mounted them yourself. If so your problem is going to be proving the tire is bad. You can tell by jacking up the tractor so the bad tire is off the ground. Place something to act as a gauge beside the tire and roll it around. You can see the tire is not round. Now somehow you need to show that to whoever is going to adjust the tire because to carry it in and say it is bad requires an act of faith on the tire store. You need to get it adjusted, just be sure you find out how before you take it apart.
Did you buy cash and carry, and mount yourself? If you did, expect problems with replacement. They will claim you overinflated, or made other errors when mounting. That is why I only buy tires and have them mount them. Tom
