Anonymous-0
I need 3 ribbed front tractor tires. Mine are 4.00-12. All I see advertised are 4.80x12. I need both front tires and am wondering if these 4.80x12 will work and how much bigger they are. Thanks.
Thanks for the quick comeback. These tires are on a David Bradley Tri Track. The tires are pretty close to the upright front spindles but should have enough room if there is only 3/4 inch wider. Thanks
I believe "Gemplers" has the 4.00 X 12 for under $40.
www.gemplers.com
1-800-382-8473
The wider tires would make steering much more difficult and strain the machine.
Actually I think they will be the same size, just the 4:80 size is a trailer tire while the 4:00 is tractor tire and just in the way they are measured.
